///M3 Forum
Old 11-03-2012, 06:30 PM   #1
msane3
My Ride: 2007 335i
Previously repaired subframe m3's and other e46's get in here!
So today I decided to swap the wheels on my m3 and give it a thorough inspection. I lifted my car up to inspect everything looked good and tight. I had already repaired small cracks on my subframe and installed the tms subframe reinforcement kit. I decided to give my rear end a close inspection with a strong flashlight. Upon deeper inspection I noticed some slight cracking above off the the side of the rear passenger's Carrier mounting point.
I was pretty shocked and have come to the conclusion that even if repaired and reinforced, the subframe will find the next weakest spot to strain and crack at. Luckily I have a decent welder and have good welding skills so I decided to throw a bead on it.
I check my subframe thoroughly every 6 months or so. Last time I checked this was not there. I only occasionally drive my car hard so this makes me weary of future problems and how many times I will have to repair this thing.
As a preventative measure I suggest you all have your car inspected regularly for cracks. They can be much more easily repaired before it turns into a major tear. Food for thought.
msane3 is offline   Reply With Quote
Old 11-03-2012, 10:38 PM   #2
Ballerbrian4u
My Ride: 2004 BMW m3
Hey, I hope it doesn't crack anymore. I have a question if I jack my car up and take the rear wheels off could I see from that point if there are any cracks?
Ballerbrian4u is offline   Reply With Quote
Old 11-03-2012, 10:40 PM   #3
msane3
My Ride: 2007 335i
You don't need to take your wheels off but jack your car up high enough to be able to get under it. A good flashlight really helps. Driver's rear point and passenger's front point where the carrier mounts are most prone to cracking.
Old 11-04-2012, 12:37 AM   #4
AzCamel
AzCamel's Avatar
My Ride: Soon To be Boosted
do you have a wider shot to show me where i should look under the car?
02 M3 SMG Vert
Dinan 3.91 / Dinan SMG Software / Dinan ECU Stage 1 / Beyern Mesh 19's / BSW Sound / EAS LED Angel Eyes / ETC..
94 Supra FOR SALE, OR TRADE FOR NSX
Precision SP63 / Tial / Apex-i / TRD / Seibon / Do-Luck / CCW / Recaro / Eibach / Top-Secret / Greddy / ETC...
AzCamel is offline   Reply With Quote
Old 11-13-2012, 10:06 AM   #5
msane3
My Ride: 2007 335i
I think I might have some better shots from when I originally reinforced my subframe. If you google e46 subframe. You will get awesome shots of the problematic areas.
Old 11-13-2012, 11:35 PM   #6
YGOSLO
My Ride: 03 CarbonSchwartz M3
Would doing the platesomined with the foam help reduce this in your opinion?
Full Black Interior For Sale
2003.5 Carbon Black/Imola Red ///M3 Coupe: Stock
2003 SVT Ford Mustang Cobra: Not Stock
YGOSLO is offline   Reply With Quote
Old 11-13-2012, 11:39 PM   #7
msane3
My Ride: 2007 335i
It might. It will be structurally a lot stronger with the foam since it won't be able to flex and rock as easily. I purchased the foam for my car but have been hesitant to use it since I won't be able to weld on the subframe anymore. It might catch fire.
Old 11-14-2012, 12:52 PM   #8
YGOSLO
You would hope no more cracks would form with the foam in there....
Old 11-14-2012, 06:56 PM   #9
avincent52
My Ride: 325iT 5 speed/Sport
YGO: Sorry to hijack, but the color combo on your car is just stunning. There's just something about red leather seats...
avincent52 is offline   Reply With Quote
Old 11-14-2012, 07:39 PM   #10
YGOSLO
Thanks, they were originally black. I got the Imola Red from another enthusiast. Really helped my love affair with the M. The black was just too bland.
