Old 11-03-2012, 07:06 PM   #1
hlfpast3
My Ride: OrientBlue 330Ci
Send a message via MSN to hlfpast3 Send a message via Yahoo to hlfpast3
Best clutch flywheel set up
I'm looking for the best clutch and flywheel set up for some spirited street driving.
I've looked at the e39 M5 clutch kit and uuc flywheel. Or considered going back to stock with the BMW clutch kit from ecstuning with the Luk flywheel.
Gimme ur opinions....
3.38 Diff
UUC SSK
Shark Injector
Conforti CAI
H&R RSS Coilovers
H&R Sways
OEM M3 Strut Bar
Reinforced Strut Mounts
Rogue Engineering RSM
ProjectorE46
M Tech II Rear
Ipod Integration
hlfpast3 is offline   Reply With Quote
Old 11-06-2012, 09:15 AM   #2
cposk
My Ride: 08' E90 M3
I went with the M5 UUC kit about 2500 miles ago. I like the stiffer feel and it isn't bad sitting in traffic like some say. Lots and lots of clutch chatter though. As long as you don't mind having to hold in the clutch while ordering in the drive through, I say go for it...
cposk is offline   Reply With Quote
Old 11-06-2012, 10:13 AM   #3
hlfpast3
I'm afraid lots and lots of chatter would annoy me. Despite the fact that this crappy clutch and flywheel are chattering as it is. I wanna order something TODAY!
How heavily modded is ur car?
3.38 Diff
UUC SSK
Shark Injector
Conforti CAI
H&R RSS Coilovers
H&R Sways
OEM M3 Strut Bar
ProjectorE46
M Tech II Rear
Ipod Integration
Old 11-06-2012, 10:17 AM   #4
SoloII///M
My Ride: Many
Personally I'd recommend staying stock with your flywheel and clutch.
Lighter flywheels make oil pump nut failures more common and without the dual mass construction they will rattle.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is online now   Reply With Quote
Old 11-06-2012, 10:22 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
It's not the clutch and flywheel that chatter. It's gearbox rattle. If it's currently doing it, it's going to do it more with a ltw solution. If you're okay with the noise, the ltw solution is a lot of fun to drive.
