Sponsored by BimmerWorld
Old 11-04-2012, 03:33 PM   #1
iondroad
My Ride: 01 330i
E46 Sticking front brake calipers
Greetings all,
I have an '01 330I that has been plagued with sticking front brake calipers since I bought it four and a half years ago. I have replaced both with remanufactured calipers, replaced the ends of the brake lines, and installed new rotors (slotted) and pads (Cool Carbon). One side inevitably sticks with the lightest application of the brakes, and takes several hours to release. Suggestions? Non-remanufactured parts? Master cylinder? Exorcist?
Many thanks, Rich
Sent from my XT907 using Bimmer App
iondroad is offline   Reply With Quote
Old 11-04-2012, 03:45 PM   #2
GolfingDuck
My Ride: 540 & 330Ci M Sport
For a long-running problem like this and having changed the calipers I would be looking at the master cylinder. Sometimes they don't fully release pressure when the brake pedal is released. The symptoms get worse and worse the more the car is run as the brakes and brake fluid gets heated up.
To test this you can go for a run and when you get back loosen the bleed nipple on a front wheel, briefly. If the brake fluid spurts out, rather than just falls out, fasten it back up and go for another run getting the brakes fully hot again. Then undo a bleed nipple on a rear wheel. If the brake fluid spurts out of that too it is likely to be the master cylinder.
GolfingDuck is offline   Reply With Quote
Old 11-04-2012, 05:48 PM   #3
iondroad
My Ride: 01 330i
Thumbs Up E46 Sticking front brake calipers
GolfingDuck,
Many thanks for your reply! I've been reading many threads on this site to get some ideas, and I'm also inclined to believe the master cylinder is malfunctioning. I can rule out warping because it rolls smoothly once the caliper releases, and I've isolated the problem as being on one side by comparing the relative amount of heat coming off of the rotors after I've driven. I can also feel the wheel binding and hear it resist turning when I start very gradually (no gas, gradual clutch release). The good news is that it goes to my regular mechanic in the morning, so this will give me an area of conversation to begin with.
I'll post my results when it comes back from the shop.
Rich:
Old 11-04-2012, 05:49 PM   #4
iondroad
My Ride: 01 330i
GolfingDuck,
Rich
Old 11-04-2012, 09:11 PM   #5
hummer
My Ride: 2001 330CI
ABS unit?
Old 11-04-2012, 09:49 PM   #6
iondroad
My Ride: 01 330i
Smile E46 Sticking front caliper
Hummer,
I did not think of that! I have sent the car to my mechanic; I will ask him to check.
Many thanks,
Rich
Old 11-04-2012, 09:53 PM   #7
///MPR77
My Ride: 02 ///M3 Tri-Ped
Start with a proper bleeding, it's the cheapest place to start.
If you have air in the hydraulics the system won't work as efficient, or properly.
Old 11-05-2012, 09:28 PM   #8
NASAE30
My Ride: 01 330CI,99 540iT
update? I have the same problem. Replaced calipers, pads, lines, and rotors and it actually got worse.
Zach Mickle
Event Director Nasa Mid Atlantic Autocross
Zach@get-fast.net
NASAE30 is offline   Reply With Quote
Old 11-05-2012, 09:34 PM   #9
iondroad
My Ride: 01 330i
NASA e30,
It's at my mechanic's right now, and he is ordering a new caliper...Not sure if this will fix it, but I sure hope so. I'll keep the forum posted.
Old 11-06-2012, 10:59 AM   #10
NASAE30
Cool. Ill add one more data point that I forgot to mention, my old calipers had the brass bushing for the slide pins. They kept seizing up, so I thought that was my problem. Not so sure anymore.
Zach Mickle
Zach@get-fast.net
Old 11-06-2012, 12:27 PM   #11
BimmersGarage
My Ride: E46 330i
I would say it shouldn't be your brass bushings - unless there's major rust on the pins. Also, you must use the supplied guide pins that came with the brass bushings! (if you use stock pins it may cause the binding issues described.
OP,
Here's my suggestion:
(assuming fresh brake fluids and proper bleeding along with those re-manufactured calipers... )
If you're still experiencing random brake binding, I'd suspect the hub bearings has failed on that particular side.
Remove the brake caliper completely (leaving the rotor on the hub) and give it a spin, see if it is spinning smoothly without
'odd' noises. If you need reference to what a failed hub/bearing sounds like, search my vids on my channel below.
Let us know what you find out.
BimmersGarage is offline   Reply With Quote
Old 11-06-2012, 08:38 PM   #12
iondroad
My Ride: 01 330i
to E46Fanatics
My thanks to all my fellow fanatics for your experience and advice. My mechanic diagnosed a bad caliper, replaced it, and is returning it to his supplier without charging me for the part! I'll keep you all updated if the situation changes.
Rich
Old 05-09-2016, 09:01 PM   #13
D1 xPrincex
My Ride: 2000 bmw 328i
I'm still having the same issue
I replaced the caliper and I'm still having the caliper stick whyle I drive but it only does it random days sometimes it won't doit for 2 weeks but sometimes it's really agressive not enjoying my car it's very stressful
D1 xPrincex is offline   Reply With Quote
Old 05-14-2016, 11:16 AM   #14
D1 xPrincex
i just ordered a new brake master cylinder to see if this will fix the problem ill let you guys know
Old 03-10-2017, 05:06 AM   #15
Mechsoldier
My Ride: 01 X5
Hey guys I just joined this for him to tell you what actually causes this it's very very rare but easy to test for. German car calipers don't often fail and often the brakes don't drag as soon as you start the car.
I first saw this problem on a Volkswagen Jetta when I worked at VW you'd start driving it and it first we find you get halfway around the block and the wheels would just lock up. After I replace the master cylinder and it didn't fix it I started thinking what could cause pressure.
What's going on is the brake booster has failed and it's putting more pressure on the master cylinder than it should until you start driving it and it gets vacuum in it and repeatedly you press the brakes and build up pressure in the brake lines it doesn't show up.
I came to the site just to see if this car had master cylinder problems even though I've never seen it but after I saw somebody people saying they replace the calipers the master cylinder etc I knew it was probably the same thing.
All you need to do to test it is pull the brake booster vacuum hose off of the brake booster and clamp the line off or plug it (the hose, the booster itself doesnt need sealed) so you don't have a giant vacuum leak then go drive the car, if your brakes don't drag anymore then the boosters putting pressure on them.
I wanted to verify before I posted and tonight I did.
I'll also mention that we've been chasing some weird fuel trim faults for about a year and after I had done the Breather hoses under the intake and it didn't fix it I was stumped about what it could be but as soon as the brake problems started it clicked and made total sense.
Warning, when you drive without the booster vacuum hose plugged in, you don't have power assisted brakes. If you're old enough to have driven a car like that, that's from the 70s or older, then you'll notice the feeling.
Basically you're going to need to use much more pedal pressure than normal, stopping distances will likely increase, brake performance will suck.
In other words, don't go hauling ass around in rush hour traffic.
Mechsoldier is offline   Reply With Quote
