General Off-Topic
Everything not about BMWs. Posts must be "primetime" safe and in good taste. You must be logged in to see sub-forums. Click here to browse all new posts. |
#1 |
Long story short Im having a problem in my 6 story building. The first story is on the ground/floor level with the boiler right under it. I have a slew of 1st floor tenants telling me its too hot in their apartment and other tenants on the 5th floor (top floor) telling me its too cold. Two of the top floor tenants are telling me that only some radiators heat up, but not all.
Earlier today I went to the hardware store and purchased some #D Steam angle vent for one of the 5th floor apartments. I changed all of the vent/valves on each radiator in the apartment. Now she's happy and she said she's getting equal heat in all of her rooms. My question is, what kind of air vents do I get to keep the heat down on the main floor apartments? Also, are the #D valves the correct ones to use on the apartments that are furthest away from the boiler room (ex: top floor) I used my laser beam thermometor and Im getting 71 degree temps on the 5th floor and near 80 on the first floor. In one apartment is was 85 degrees in the bathroom. I dont want to lower the temperature on the thermastat because I dont want it to drop below 69/70 on the 5th floor. System Im working with, a HB Smith gas boiler and 1 pipe old school traditional radiators. Its a steam boiler and the water levels are constantly at adequate level since I cleaned the self feeder. Thanks very much in advance. Here's one of the air vents that were installed in the 5th floor. ![]() ![]() ![]()
..George.. ..Is now Alpine White/Cinnamon... ![]() ![]() ![]() ^Don't say my car is topless, say the t!tties is out^ Last edited by DropTopKingM3; 11-05-2012 at 12:35 AM. |
#2 |
Steam radiators, lol, what a sh!t hole.
Gutted with a Getrag
#3 |
Anything but a sh!t hole, but thanks.
..George.. ..Is now Alpine White/Cinnamon... ![]() ![]() ![]() ^Don't say my car is topless, say the t!tties is out^ |
#4 |
Wait, what year are we in again? I wasn't aware it was 1884.
#5 |
Most of the buildings in NYC have steam radiators. My building was built in 1931. If it aint broke, why spend all that money fixing it?
#6 | |
#7 |
Steam is by far the best way to heat. I have central heating and air in my place and WISH I had steam.
![]() Last edited by NFRs2000nyc; 11-05-2012 at 06:50 AM. |
#8 |
Stay stock my friends!
I'm not a plumber and not familiar with steam, but doesn't each radiator have a valve you could close down on lower floors and open up on top?
Also, I know there is a delay setting on thermostat...and depending on where thermostat is...can be adjusted to run longer when it's on so hopefully the steam gets up high. GL!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#9 |
I'm not a plumber but this video might help.
http://www.thisoldhouse.com/toh/vide...638722,00.html |
#10 |
Tinfoilhatatarian
My Ride: .
Sounds like you need to bleed the system
Malo periculosam libertatem quam quietum servitium
#11 | |
a gas furnance, or hell even those weird A/C / furnace combos worked better and much more precise for me one thing I DID notice about gas furnace heating is I prefer the central air duct to be located on the ceiling and not on the floor, even though heat rises. The difference (to me) seemed rather significant and the feeling of warm air blowing on your back while you're in bed is quite nice.
![]() Last edited by v8 5; 11-05-2012 at 10:30 AM. |
#12 |
Post a picture of the Radiator Valves. Every valve has a set Orifice this determines how much the valve can open too..
#13 | |
sorry man, I just had to.The idea of steam-powered anything just strikes me as anachronistic. |
#14 | |||
The valves are supposed to self bleed. The defective ones weren't bleeding on their own but the new ones did. Quote:
#15 | |
#16 |
Tinfoilhatatarian
My Ride: .
Yes..... because nuclear power plants are anachronistic
#17 |
this go to the highest floor, dont burn yourself. the radiators shouldnt all be on the same loop. they should also have valves like these https://www.blastlineind.com/Product...Fek7OgodLzwAZg to isolate each radiator
maybe you arent describing your situation exactly correctly. im a plumber Last edited by andrewrossnagel; 11-05-2012 at 01:50 PM. |
#18 | |
Personally I hate heat and never turn it on in my home. Sometimes I leave my window open because I love fresh cold air. When it gets bitter cold out I close the window, otherwise it stays open. In this building that I speak it gets comfortably warm. Hopefully by later today Ill be able to maintain the same temps all around the building. Its funny that my building is the only one on this street that never lost power. Every street around within a 4 block radius lost power, heat, cable, etc due to hurricane sandy.. My diva tenants cant appreciate the fact that they have TOO much heat but they choose to call me at midnight on saturday night and 8AM sunday morning to complain. I sorta wish the power did go out there, maybe they would appreciate things more #end rant.
..George.. ..Is now Alpine White/Cinnamon... ![]() ![]() ![]() ^Don't say my car is topless, say the t!tties is out^ Last edited by DropTopKingM3; 11-05-2012 at 01:51 PM. |
#19 |
I don't immediately think of nuclear power when I think of steam power.
To me it conjures up images of locomotives or something from the "Hellboy" franchise. Surely you understand I jest. |
#20 | |
