Engine Smoking in engine bay - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-05-2012, 01:32 AM   #1
KaziKai
My Ride: 2001 325i
today I popped open the hood while the engine was one and there were smoke coming from the engine like it was burning oil or something but there were no leaks below.. I just got this 2001 E46 325i Sedan and now im worried...
What should I do.. I know if I take it to BMW.. my wallet will be done.. anyone here in Vegas could give me some tips or a place to go?
thanks!
KaziKai is offline   Reply With Quote
Old 11-05-2012, 01:33 AM   #2
E46_330_Ci
My Ride: 330 Ci 2001
It will most likely be the valve cover gasket
E46_330_Ci is offline   Reply With Quote
Old 11-05-2012, 02:10 AM   #3
KaziKai
My Ride: 2001 325i
is that easy to do?
Old 11-05-2012, 02:11 AM   #4
KaziKai
My Ride: 2001 325i
if i leave it alone for now... will it kill my beemer?
Old 11-05-2012, 02:25 AM   #5
E46_330_Ci
Well I just did my valve cover gasket about a week and a half ago is not that hard for some it is of your a dyier guy you could tackle this job just check if your dropping oil on your left side of your engine passenger side the smoke comes from the oil dropping in the exhaust causing white smoke to come out just check your oil regularly to make sure you good on oil if your not dropping to much you can roll like that for a while until you replace it
Old 11-05-2012, 02:28 AM   #6
KaziKai
My Ride: 2001 325i
ok thanks ill go order the part and when it gets here ill change it.. I should have all the right tools for it... if not i be screwed... Thanks..
that is my no. 1 to do list tmr!
Old 11-05-2012, 02:32 AM   #7
E46_330_Ci
Just make sure tomorrow if you have oil dropping
Old 11-05-2012, 07:19 AM   #8
stingray71
My Ride: 2005 325xi
DIY - not too bad
Originally Posted by KaziKai View Post
is that easy to do?
I am new to BMWs but I did this last week. The hardest part was actually removing the valve cover from the old gasket because it was really stuck on the engine. I had to pry very carefully, but forcefully to get it off the engine.
I would allow about 3 hours and read over the instructions and required tools before you begin. It will not be that hard and will save you a lot of money.
This thread (first picture) shows exactly the leak that I was having:
http://forum.e46fanatics.com/showthread.php?t=882732
This thread is a great DIY thread with pictures showing you every step.
http://forum.e46fanatics.com/showthread.php?t=886063
If you are leaking oil, it will not be good for your engine, so you don't want to let this go too long.
Good luck.
stingray71 is offline   Reply With Quote
Old 11-05-2012, 12:11 PM   #9
KaziKai
My Ride: 2001 325i
Good luck.
Thanks! I need to go pick up some tools...
Old 11-05-2012, 12:18 PM   #10
haurelio
My Ride: 2001 bmw 325i
you can also loan tools from your local auto parts store..
Contact me if you need to unlock your phone.
Also can code your car
Old 11-05-2012, 12:26 PM   #11
trj
My Ride: 325Ci
Has to be VCG.
Order VCG and 15 rubber grommets.
I'd advice not to use victor reinz gasket, I had to re-do the VCG in 4 months after I replaced it with victor reinz. I'd rather order elring or OEM gasket.
OP, I'd prefer you to use a torque wrench if you are doing this kind of job for the first time. The studs are easy to break if you over-torque them.
7~8 ft lbs of torque is what is needed to wrench those cap nuts.
If not a torque wrench, then once its snug hand tight, just a quarter turn is all it takes to get to that kind torque.
Good luck.
Its an easy job(around 3 hours slowly), but careful not to drop anything inside the engine.
Also, if you want to do the spark plugs its a good time.
Tip: warm up the engine a little(not fully warm, it will burn your fingers). It helps to remove the old gasket easily, as heat makes it a little soft.
Old 11-09-2012, 07:19 PM   #12
KaziKai
My Ride: 2001 325i
Originally Posted by trj View Post
Has to be VCG.
Good luck.
OK thanks for the tip!
I did get the VCG's.. I was told by a buddy of mine as well he did say get those VCG's or your going to be visiting the engine bay in 4-6 months to redo what you have did..
there is one thing that I was wondering was the silicon gasket seal stuff.. what brand so I get and use? I see they have the high temp ones and there are others that are high temp and permanate versions.. Im just not sure what is a good one to use...
and yes I have that in mind to change the spark plugs but not sure which one would be good to use...
bosch +4 or
NGKs...
Old 11-11-2012, 12:41 AM   #13
Cheet22
My Ride: E46 323i
This may sound crazy but double check it is the vcg. I had white smoke coming from back of engine but could not see oil on exhaust. But i changed it assuming it was that, but it still did the smoking.
The crazy thing is, it was actually my gearbox pan. It was leaking slightly from a hole in it, and when i drove it threw the oil backwards onto the exhaust about midway beneath the car. The smoke however travelled along the exhaust then to the front and out the engine bay when i stopped moving. Why i saw no smoke out the side or back of the car was the strangest thing. The smoke seemed to just follow along the exhaust as if it was attracted to it.
If it is the vcg its a real easy job to be honest just take your time.
Plugs- i went for the ngk iridium on my 330
Sealant - here in the uk i just went to motor factors and asked for correct flexible gasket sealant. It was red stuff i can remember that much!
Cheet22 is offline   Reply With Quote
