Old 11-04-2012, 04:02 PM   #1
220k330
My Ride: 2001 330ci ZSP
coolant drip...drip...drip...drip
hey guys, well I did replace my radiator with one from Pelican about 2 months ago and everything was good to go...get home today after running errands...drip....drip....drip.....crawl under the car....the coupling point between the lower hose (heater hose maybe?) off the reservoir and the reservoir is dripping steady....here is the million dollar question...I know I need to take it all apart to see what is what to begin with but....can I maybe just replace the o-rings in there or will I need an entire new hose? --- I did replace my reservoir about a year ago...I had been planning on doing my water pump, off-set roller, and tensioner anyway soon, so I parked it until I get all my parts together....
suggestions on the current drip?
220k330 is offline   Reply With Quote
Old 11-04-2012, 04:06 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
well if you never changed the hose you should get a new one. cheap insurance.
Old 11-04-2012, 04:15 PM   #3
220k330
is that hose the "Water Hose, Water Pipe to Expansion Tank" hose?
Old 11-04-2012, 05:13 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
AFAIK, no one has found a PN for just the o-ring in the hose, but that's probably all it is. Hoses are pretty good. But failing that, the hose sounds like your issue. Maybe you'll get lucky and you just need to push it on further...but not too likely.
If you drained the entire system when doing radiator, save what coolant you can and strain through paint strainer. You probably could find 0-ring...and if it's the hose going to the hard pipe, good luck. That one took me an hour to get apart since I didn't want to be too rough on the hard pipe. It's pretty firm, but still, old brittle plastic. If the hard pipe cracks, you have to remove intake mani to get it.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-04-2012, 06:45 PM   #5
220k330
So the o-ring in the hose fails? Can I just try and match up an o-ring? Is it made as part of the hose? And I already made sure I had it installed all the way in
Old 11-04-2012, 07:04 PM   #6
Zell
Zell's Avatar
My Ride: so turbo wow
The O-ring is inside the hose, you can see it when you take out the hose.
It is removable, I just removed it from my old one just now. Here are some reference pictures to help find the right size:
Old 11-04-2012, 07:09 PM   #7
220k330
Sweet! I'm oing to try that first!!! Appreciate it!
Old 11-04-2012, 07:14 PM   #8
Zell
Zell's Avatar
BTW:
http://diytoolshopper.com/product_in...621e8fb106558f
Best thing you can have in your toolkit!
Old 11-04-2012, 07:17 PM   #9
220k330
Nice!
Old 11-05-2012, 04:27 PM   #10
SDpnoy
My Ride: 330Ci and M3
I see that you have a 2001. I would recommend replacing the hose as well. I'm replacing mine this week.
SDpnoy is offline   Reply With Quote
