Sponsored by The Tire Rack
Old 11-06-2012, 01:45 AM   #1
chad h
My Ride: '01 330i Manual
De-stagger
So I have the sport package. Currently running staggered tires. I really don't like the whole lack of rotation deal, and my car is mainly used for commuting and not high performance situations.
Is it a bad idea to go the same size all around? If not, what size is recommended?
I believe my wheels are style m68.
Thanks for the help
Chad
chad h is offline   Reply With Quote
Old 11-06-2012, 02:02 AM   #2
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
It's not a bad idea. Depending on how aggressively you drive it may change the car a bit. By design the staggered setup introduces understeer. Go to a squared setup (non-staggered) and you reduce the tendency to understeer so the car will become more neutral when cornering. If you don't drive aggressively you probably won't notice it and you'll be able to rotate your tires.
You should be able to get another set of M68's fairly inexpensively and mount the rears in both the front and the back running a 245/40/17 all season tire. The rim would be 8.5" wide and with a 50 offset would extend the rim into the wheel well an addition 21.7mm over the stock M68 7.5" front. As long as your running stock suspension you won't run into clearance issues with the struts.
/// MODS
Old 11-06-2012, 03:15 AM   #3
vadim
My Ride: 08 E92 335i, 05 325i
BMW does not recommend rotating wheels (regardless of the setup being staggered or not). This is explicitly stated in the user's manual.
vadim
'05 E46 325i MT
'08 E92 335i MT
'11 X5 35d
vadim is offline   Reply With Quote
Old 11-06-2012, 07:17 AM   #4
WDE46
My Ride: '13 128i, '04 330Ci
I've never understood this. I can't think of a good reason not to rotate tires.
Old 11-06-2012, 08:08 AM   #5
GT172I
My Ride: M3 ZCP, 335is, 330ci
Makes zero sense to me either when running a square setup. Staggered yes since that would have major impacts to handling when they get mixed up. Since most (all?) come staggered OEM of course the manual would advise against the typically common practice.
APEX ARC-8's | UUC EVO3 SSK | UUC TSE3-L | H&R sways
Stebel Truck Horn | Misc cosmetic stuff
GT172I is offline   Reply With Quote
Old 11-06-2012, 09:57 AM   #6
Wolrab
My Ride: 330Ci MT, 545i SMG
I went square with my E60 after the first set of tires. As far as I can tell, the handling hasn't changed, and I'm spending 25% less on rubber. My girlfriend doesn't want to do it on the E46, but her reasons are cosmetic.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-06-2012, 10:32 AM   #7
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
Are you people running non-directional tires? That's the only place I could see you saving money by rotating. Rotating on our cars saves us from crazy camber wear, which happens on the inside of the rears and fronts, so the only way to combat it is to either run non-directional tires or have the tires demounted and remounted halfway through their life which is going to cost you more to do than to just leave them and replace it earlier.
I have all directional, so I don't even rotate. When the rears wear out on my E46, I replace them. When the staggered rears wear out on my Z4, I replace them. When the fronts wear out on either, I replace them. Easier to stomach $300-400 twice a year than $600-800 once a year per car. (yes, I run high performance tires, drive the **** out of my cars, and drive 35-40k miles a year)
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 11-06-2012, 10:34 AM   #8
Zell
Zell's Avatar
My Ride: so turbo wow
I think most people go with a square setup. I like my staggered look, though
Old 11-06-2012, 10:40 AM   #9
Wolrab
Directional tires or not, you don't want to go switching direction. When I "rotate", fronts go to rear and rears go to front. Left stays on left, and right stays on right.
Before I went square, I was getting 20k out of the rears, and 35k to 40k on the fronts before the noise got too bad. Now I'm getting 40k on all of them. That's where my rubber $$$ savings comes from. They actually wear out before the noise gets bad.
Edit: I spend $0.03 per mile on tires; my girlfriend (staggered) spends $0.045.
Old 11-06-2012, 10:43 AM   #10
My Ride: Lexus
Staggered setup is not for performance reasons on BMWs, OP. By "squaring" or equalizing all wheels/tires, you are actually doing a performance upgrade (that's a good thing).
Obviously, WDE, the reason why BMW doesn't recommend rotating tires is because its cars usually feature staggered setups. For non-staggered setups, because BMW alignments usually feature lots of rear camber + toe-in. This develops a unique and aggressive wear pattern and rate which would typically be unfit for usage on the front axle (steering input) so as a result, it's typically better to not rotate on a BMW. This is how I understand it anyway.
Old 11-06-2012, 10:55 AM   #11
NOVAbimmer
My Ride: E60M
I see you're also going with the green tire mod. Have you noticed any gains? performance or otherwise?
NOVAbimmer is offline   Reply With Quote
Old 11-06-2012, 11:02 AM   #12
My Ride: Lexus
Well originally I went with it because DMAX told me it's popular with the ladies. I drove by a couple of clubs and no response.
But now that you mention it, my car does feel "lighter" on its feet so I've decided to keep the mod. I'm going to go to Costco and have them give me matching valve stem caps.
This is how I looked when I pulled up to the club:
Old 11-06-2012, 12:40 PM   #13
jneumann
Unless you changed tire categories, or drastically modified your driving style, that doesn't seem physically possible. Either that, or you were tossing your tires before they were worn out.
Old 11-11-2012, 10:44 AM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Mango,
You need to get those tires Fern Green Metallic if you want the ladies.
You're welcome!
See me in June!
dmax on Facebook
Mangofy your E46!
