Old 11-06-2012, 12:29 PM   #1
BMWjunkie77
My Ride: 2002 ///M3
Possible Clutch Adjustment Needed???
As I am sure is the case of most of your cars, my M3 has a minor bit of vibration in the clutch when driving it, but recently I have noticed a bit more vibration then normal. My father borrowed my car the other day and the first thing he said when I got it back was the clutch was vibrating to much and I need to adjust the clutch. I've been looking around a bit and cant seem to find to much on the subject. There is only 36k miles on the car, is it possible this increase in vibration is a call for an clutch adjustment? I have no problem tackling the project, I just want to make sure its the case before I start to rip things apart. In some things I found people said it also maybe that the clutch or flywheel may have uneven surfaces, any possibility to that being the case? Thanks in advance.
2002 Jet Black/Grey ///M3
Full Supersprint Race Exhaust l PSDesigns Velocity Stack Kit l TMS Pulleys l TTFS Custom Alpha-N Tune
"Bags are for dead hookers"
BMWjunkie77 is offline   Reply With Quote
Old 11-06-2012, 02:06 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
when are you getting the vibration? when its fully engaged or when you are slipping it.
if its a gazed flywheel due to overheating, you will get this bad vibration when you slip it. almost feels like the transmission is gonna fall out of the car.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
