Old 11-06-2012, 01:48 PM   #1
KSims1868
My Ride: 2001 BMW 325i
Burnt oil/rubber smell only when stopped
The last few times I've left my car running while I run into a convenience store or wherever it will be idling for a few minutes. When I get back in the car it smells like I've been sitting behind an old school bus with the windows down and the bus exhaust being blown into my car. When I drive away the smell quickly goes away.
I'd say it smells sort of like burnt oil or rubber I guess...and it's bad.
Only thing done recently was an oil change 6-8 weeks ago, and didn't notice anything out of the ordinary (no smells) until this past weekend.
KSims1868 is offline   Reply With Quote
Old 11-06-2012, 02:10 PM   #2
stingray71
My Ride: 2005 325xi
It could be your leaking valve cover gasket. Check out this thread and the responses. There is a link that shows the possible leak location and the DIY for the fix.
http://forum.e46fanatics.com/showthr...206&highlight=
stingray71 is offline   Reply With Quote
Old 11-06-2012, 02:11 PM   #3
trj
My Ride: 325Ci
Classic VCG leaking symptom.
Look at the passenger side at the engine, the last and second last bolts holding the VCG should be leaking.
The oil drips on the hot exhaust and gives the smell.
Old 11-06-2012, 02:14 PM   #4
KSims1868
Okay I'll check it out when I get home from work.
Looks like I might be smelling my next weekend project.
Old 11-06-2012, 02:15 PM   #5
Wolrab
Registered Gadfly
Wolrab's Avatar
My Ride: 330Ci MT, 545i SMG
Send a message via Skype™ to Wolrab
Where the hell do you find a convenience store around here, that you would leave your car outside, running? Maybe you have a passenger who's armed to the teeth.
Edit: It's a pretty straightforward project, but PM me if you run into snags. I can give you a hand.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-06-2012, 02:51 PM   #6
KSims1868
I'm down in League City/Friendswood (Clear Lake area). I sure as heck wouldn't leave it running inside Houston city limits...no way.
Old 11-06-2012, 03:07 PM   #7
Wolrab
Registered Gadfly
Wolrab's Avatar
Ahh, that makes a bit more sense. I work at Greenspoint, aka Gunspoint. Any kind of a breakdown around here can be life-threatening, so I like to keep my cars mechanically pristine.
Old 11-06-2012, 03:29 PM   #8
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
You can buy a good .45 ACP 1911 for the $700 you'd spend on a cooling system. Then you can refill your leaking system with gangster blood on the side of the road.
Old 11-06-2012, 03:36 PM   #9
Wolrab
Registered Gadfly
Wolrab's Avatar
Is that the State Gun of Utah? Or is it a Browning M1911? I don't remember.
I guess that would be another definition of "bleeding every time you add coolant".
http://en.wikipedia.org/wiki/List_of...state_firearms
Old 11-06-2012, 04:12 PM   #10
thefrog1394
My Ride: e46- 1999 323i
valve cover gasket
Photo in Cleveland, Ohio
1999 323i - 210,000 miles and counting.
Rear Wheel Bearing Tool (SitTools B90) Rental, ~$60
thefrog1394 is offline   Reply With Quote
