Sponsored by BAVSOUND
Old 11-06-2012, 03:01 PM   #1
Barneyhyphen
My Ride: 2004 M3 Convertible
Possible speaker replacement?
2000 323i Non-HK. All mid/bass speakers shot.
My understanding is that the lower two speakers in the front doors and the two in the rear deck are all the same, correct?
http://cheapcarspeakersystems.blogsp...-300-watt.html
Would the above be suitable (better than stock) replacements?
They are 4 ohm instead of the stock 2 ohm, is this a problem?
They are 2.84" deep, does this mean they will fit in the rear shelf but not in the doors?
Any other things I should know?
Thanks.
BH
Last edited by Barneyhyphen; 11-06-2012 at 03:05 PM. Reason: incorrect placement of thread
Barneyhyphen is offline   Reply With Quote
Old 11-06-2012, 03:28 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
You should try to get the same resistance. That won't be a huge difference, but you should if you can. If you can't, I believe it is better to get a higher resistance (like the ones you have chosen) to keep the current down. I=V/R, so a higher resistance will lower the current and power and keep your amp alive. Someone with more audio knowledge please validate this, though I am pretty sure it's correct.
Old 11-06-2012, 04:31 PM   #3
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The HiFi system (none HK cars) uses 3 speakers in each door. You have a woofer located in the lower door panel, a mid located near the center area of the door panel and a tweeter located on the top of the door. If you'd prefer to pick up factory replacement speakers, I have them avaible HERE for your car.
Old 11-06-2012, 07:16 PM   #4
DBrown
My Ride: BMW 325 Ci
I replaced my stuff with bsw, an absolutely love it. If you got the money I would definetly recommend them. Yes that are expensive, but incredibly smooth speakers. If you like good sound. They are worth it. I was very impressed I like them better for midranges and tweeters than my old jbl, alpines and kaption audio ones. Which have been in this car and others.
The new ones from ecs will also do the job and be a lot better then the current ones you have. Bsw route is an expensive one.
2001 325 Ci
DBrown is offline   Reply With Quote
Old 11-06-2012, 07:19 PM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Go with BSW, they're direct replacements. They spent a lot of time making them work for our cars. It's as easy as unplugging the old ones and plugging the new ones in.
Old 11-06-2012, 10:46 PM   #6
Megalocnus
My Ride: 05 330i ZHP/MT
Thanks.
BH
Yes, the four midbass drivers are same.
I don't know if these Pyle speakers will count as an improvement over the stock speakers, but they should work alright. Perhaps they'll be quieter than the stocks, them being 4 Ohm vs. 2 Ohm, but that's something you can fix with the equalizer.
With these, your primary concern should be fitment, not sound quality. You will have a hard time fitting these in the front. They have an outer diameter of 6.64". Anything larger than 6.25" - 6.3" will require a lot of work to make it fit on the front door panels. I don't think doing this for some $10 speakers will be worth the effort.
I went with Infinity Reference 6032si, $50 per pair, they fit directly with adaptors ($10 per pair on Ebay). The adaptors needed a bit of work with a rough file and a drill. You can also make them yourself from some thick plastic. The 6032si is a two-way speaker, 4 Ohm tweeter+4 Ohm midbass/midrange, total impedance of 2 Ohm. Most likely the tweeters don't do anything since the amp shouldn't send high frequencies to the midbass, but all in all I'm pleased with the result.
Megalocnus is offline   Reply With Quote
Old 11-07-2012, 02:39 PM   #7
Barneyhyphen
Thank you all for the constructive input/suggestions. My daughter is buying these for herself so $'s is certainly a driving factor.
BH
Old 11-09-2012, 06:25 PM   #8
Jeremy Bavsound
My Ride: Bavsound
Our speakers on top of being plug and play and sounding significantly better than an OEM speaker also carry a 4 year warranty. She would be very pleased with the sound improvement, and it would also allow her to not have to worry about another OEM speaker failing!
Jeremy Whittle
jeremyw@bavsound.com
Bavsound | Audio Solutions for YOUR BMW
www.bavsound.com | 404.381.1800
Jeremy Bavsound is offline   Reply With Quote
Old 11-14-2012, 10:51 PM   #9
RJDaly28
My Ride: 2002 M3 SMG
This is probably your best "drop in" option. Those Pyles will be tough to fit and the few of those I've listened to before were not very high quality speakers.
If the $599 for the BSW stuff is a bit more than you want to go I am selling basically all of the HK stuff that just came out of my car. It all works fine and would just drop in. (the speakers, not the amp, etc)
http://www.e46fanatics.com/forum/sho...d.php?t=956036
$150 for the 6 speakers I have and you're done.
RJDaly28 is offline   Reply With Quote
