Old 11-06-2012, 02:54 PM   #1
jcallanan
My Ride: 2000 328Ci
Name This Oil Leak?
I know, I know, there are a gazillion posts trying to figure out where an oil leak is coming from. I havee looked at a bunch, but I'm not certain I can nail this down. Figured I'd post a few pics and see if anyone has any opinions.
It's leaking a pretty decent amount - I've lost more than a quart in the last couple of days.
First I checked the oil filter gasket and tightened it to rule that out, then I cleaned the underside of the engine with engine cleaner/degreaser and started it. within a few minutes, the leak started - it's coming down on the driver's side of the engine right near the front. You can see it clearly in the pics.
I did the vanos seals and the vgc about 5-6 months ago. I don't know if that is it, but I would not rule it out. The OFHG looks to be ok, but not positive. Any input would be greatly appreciated.
Name:	oil-leak underside 2.jpg
ID:	477078   Click image for larger version
Name:	oil-leak underside 3.jpg
ID:	477079   Click image for larger version
Name:	oil filter cover ring.jpg
jcallanan is offline   Reply With Quote
Old 11-06-2012, 02:57 PM   #2
Fajitas
My Ride: 04 E46
Vanos oil line and OFHG. Change them both at the same time along with new crush washers. JMHO
Fajitas is offline   Reply With Quote
Old 11-06-2012, 03:16 PM   #3
Wolrab
Registered Gadfly
Wolrab's Avatar
My Ride: 330Ci MT, 545i SMG
Send a message via Skype™ to Wolrab
Agreed. When you get in there, you might also find leaks from the PS reservoir and feed/return hoses. You can replace the hoses or trim and re-clamp. Either way, not high $$$.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-06-2012, 05:35 PM   #4
jcallanan
My Ride: 2000 328Ci
Thanks guys - will pull it apart this week. Parts on order.
Old 11-06-2012, 06:01 PM   #5
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
Clean things up and look again in a few days just to confirm.
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
