Old 11-06-2012, 03:54 PM   #1
jcallanan
My Ride: 2000 328Ci
Name This Oil Leak?
I know, I know, there are a gazillion posts trying to figure out where an oil leak is coming from. I havee looked at a bunch, but I'm not certain I can nail this down. Figured I'd post a few pics and see if anyone has any opinions.
It's leaking a pretty decent amount - I've lost more than a quart in the last couple of days.
First I checked the oil filter gasket and tightened it to rule that out, then I cleaned the underside of the engine with engine cleaner/degreaser and started it. within a few minutes, the leak started - it's coming down on the driver's side of the engine right near the front. You can see it clearly in the pics.
I did the vanos seals and the vgc about 5-6 months ago. I don't know if that is it, but I would not rule it out. The OFHG looks to be ok, but not positive. Any input would be greatly appreciated.
Name:	oil-leak underside 2.jpg
ID:	477078   Click image for larger version
Name:	oil-leak underside 3.jpg
ID:	477079   Click image for larger version
Name:	oil filter cover ring.jpg
jcallanan is offline   Reply With Quote
Old 11-06-2012, 03:57 PM   #2
Fajitas
My Ride: 04 E46
Vanos oil line and OFHG. Change them both at the same time along with new crush washers. JMHO
Fajitas is offline   Reply With Quote
Old 11-06-2012, 04:16 PM   #3
Wolrab
My Ride: 330Ci MT, 545i SMG
Agreed. When you get in there, you might also find leaks from the PS reservoir and feed/return hoses. You can replace the hoses or trim and re-clamp. Either way, not high $$$.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-06-2012, 06:35 PM   #4
jcallanan
My Ride: 2000 328Ci
Thanks guys - will pull it apart this week. Parts on order.
Old 11-06-2012, 07:01 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Clean things up and look again in a few days just to confirm.
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
