Heat Issues w/my 2000 328CI - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-06-2012, 07:50 PM   #1
Crazyhorse18
My Ride: BMW 328ci
Unhappy Heat Issues w/my 2000 328CI
New to you all here and would like to say hello and hope to follow this site as long as I can. My coupe has heat one day and then the next, none at all. Don't know if I'm not making the proper adjustments (this is my 1st. BMW) or what could be happening, but winter is here in the Northeast and I nnnneeeeeeddd some heat. Any info or advice will greatly be appreciated.
Crazyhorse18 is offline   Reply With Quote
Old 11-06-2012, 08:29 PM   #2
aikmanson
My Ride: E30
Sounds A LOT like me to air in your cooling system. I had a similar problem, would have heat while driving then 10 mins later lose it. Turns out my T-stat got stuck closed a few months later, after overhauling the whole system the problem was gone.
If I were you, I would overhaul the entire cooling system (if you don't know when it was last replaced, then replace it). Make sure to bleed the system properly.
Start by running coolant temps via the onboard OBC, search on here if you need help on how to do so.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 11-06-2012, 11:32 PM   #3
willsbma
My Ride: 99 323i
I had intermittent heat problems. Check that water pump.
Sent from my DROIDX using Bimmer App
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 11-07-2012, 08:29 AM   #4
Crazyhorse18
My Ride: BMW 328ci
Heat Issues for my 328CI
Okay, I'm gonna have that chkd. out today. Thanks !!
Old 11-07-2012, 08:34 AM   #5
Crazyhorse18
My Ride: BMW 328ci
That came to mind right away but I'm not seeing any change in the temp gauge. I'm gonna have that and the water pump chkd. out today. Thanks !!
Old 11-07-2012, 09:30 AM   #6
jasonbimmer
My Ride: 2001 BMW 330xi
no change in temp gauge as in the needle wont stay solid in middle after 5 mins? maybe a thermostat problem.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
