I'm afraid guys - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-07-2012, 09:27 AM   #21
jasonbimmer
My Ride: 2001 BMW 330xi
change it see if it helps. aways start simple stuff.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-07-2012, 09:28 AM   #22
FoxEyes
My Ride: 328i & M5
sell the car as is and allow no test drives
FoxEyes is offline   Reply With Quote
Old 11-07-2012, 09:42 AM   #23
gusmagoo
My Ride: 325CI coupe M-sport
Stop it! Now I know you're taking the p***!
http://forum.e46fanatics.com/showthread.php?t=954635
Read and absorb!
gusmagoo is offline   Reply With Quote
Old 11-07-2012, 10:22 AM   #24
straight_beamin
My Ride: 2000 bmw 323i
try a flush it may help, if you get it looked at and it is on its way out do a manual swap. even if you pay to do it you are looking at 3000-4000 dollars. seems like alot but a rebuilt auto is 3500 anyways and repairing yours will be 3000 and you are still stuck with a tranny that has 209000kms on it. Someone on here is selling a manual swap kit for like 1000 dollars. (add 1000 for new clutch and random parts and you are golden). seems like a big job but i did it and i couldnt be happier.
straight_beamin is offline   Reply With Quote
Old 11-07-2012, 10:43 AM   #25
DBrown
My Ride: BMW 325 Ci
I'm gonna do the fluid change but swapping the tranny is just way out of my price range, i got maybe a 1000 in available cash right now. After fluids even less, so if i need a new tranny then looks like the car will be parked for a while. Currently i have practically no expendable income cause its gone to university. Hopefully the fluid and filter works, or else ill be taking the bus.
2001 325 Ci
DBrown is offline   Reply With Quote
Old 11-07-2012, 11:03 AM   #26
adaseb
My Ride: 2002 BMW 320i
Where are you located in Canada?
adaseb is offline   Reply With Quote
Old 11-07-2012, 11:15 AM   #27
pawelgawel
My Ride: 330CI
Derek keep me updated..
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 11-07-2012, 11:47 AM   #28
Silversixspeed
My Ride: Too many to list
You goofy Canadians.
Almost sounds to me like it might be low on fluid.. Do you know of any leaks? Puddles in the driveway at all?
Silversixspeed is offline   Reply With Quote
Old 11-07-2012, 12:02 PM   #29
golf_234
My Ride: E46, E90
Please read in detail. This job MUST be done correctly.
If you indeed have the ZF 5HP19,
-Fluid: ESSO LT 71141
-Oem Gasket, Filter
-Job Cannot be done properly without measuring temperature. Period. (Small secret: while you generally need to plug into onboard diagnostics to read trans temp, you can use one of those temperature laser pointers to the pan and you will be very close)
-Verify shop knows what they are doing
Fill procedure: (there is NO alternative to this)
http://www.bimmerfest.com/forums/att...1&d=1257110016 page 4 and 5. This document will tell you absolutely everything about the transmission and how to service it. After reading it, you will probably know more than the shop.
golf_234 is offline   Reply With Quote
Old 11-07-2012, 12:02 PM   #30
golf_234
My Ride: E46, E90
Also this thread is quite valuable
http://www.bimmerfest.com/forums/sho...d.php?t=409201
Old 11-07-2012, 01:54 PM   #31
DBrown
My Ride: BMW 325 Ci
Shop has all that you talked of he said that he does the fluid changes all the time. Thinks that the fluid might fix it. I made sure he's using the proper fluid and everything plus pretty honest guy.
Also I live in London Ontario during the school year at my apartment and I'm in markham (north gta) the rest I the time.
2001 325 Ci
Old 11-07-2012, 02:15 PM   #32
Stinger9
My Ride: '04 330Ci
Please come back and tell us what that fluid change accomplishes.
Old 11-07-2012, 10:02 PM   #33
adaseb
If the fluid doesn't fix the issue. Here are a few auto auctions near you.
http://www.adesapublicauctions.ca/
http://www.mckenzieauction.com/
http://www.barrieautoauction.com/
Old 11-07-2012, 10:09 PM   #34
MercForHire
My Ride: M235i 6MT
No need for all that trouble dude.
Get a can of plasti-dip and dip the wheels, black out all corners and tail light, put a nice used $50 subwoofer in the trunk.
Unload the car at a high school nearest you!
Old 11-08-2012, 07:53 AM   #35
DBrown
My Ride: BMW 325 Ci
hey! i was thinking of plasti dipping my snow rims
2001 325 Ci
Old 11-15-2012, 08:18 AM   #36
DBrown
My Ride: BMW 325 Ci
So just got the car back last night from my local shop. They adjusted my transmission linkage ? If that's the term, I know it's just the parts that connect the shifter to the tranny, anyway adjusted them so it goes into gear better now. Fluid flush and fill, new filter and gasket. Tranny shifts as it should now. Back to normal, so I'm pleased. Don't know how it will hold up in the future, but my first impressions are that the fluid fixed it. They guy also said I should be good to go for a while, he thinks there's quite a bit of life still in that old tranny.
2001 325 Ci
Old 11-24-2012, 08:27 AM   #37
straight_beamin
Good work. They are about 3000 to rebuild so im assuming you spent a few hundred?
Old 11-24-2012, 10:40 AM   #38
DBrown
My Ride: BMW 325 Ci
Spent 400, a little more then I should have but I'm satisfied that it was done by someone who knew what they were doing. Cause I wasn't comfortable DIYing anything with my transmission.
2001 325 Ci
Old 12-01-2012, 02:50 PM   #39
straight_beamin
Good job, hey 400 beats 4000
Old 12-01-2012, 04:36 PM   #40
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
I've had this SAME EXACT thing happen to me. Get the transmission Range Sensor checked, it fixed my problem. as well as your ATF, you never know if it leaks out or something.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
gear stuck, slippage, slipping, transmission
