f*#*ing potentially expensive air con fix - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-07-2012, 04:39 AM   #1
ryanmyo
My Ride: 325i Imola M Sport
Had a chat with my mech today after i had my 3 serviced, got me worried my a/c leak might be the evaporator. I have a shhh-ing noise sounds a bit like a blow off valve coming, i think from my dash when i take off in the morning.
Anyone know of any specific evaporator symptoms? As opposed to other o-ring leaks etc?
ryanmyo is offline   Reply With Quote
Old 11-07-2012, 09:19 AM   #2
Wolrab
My Ride: 330Ci MT, 545i SMG
Do you actually have a leak that you're trying to find? According to another recent thread, that sound you're hearing is pretty common, and it's probably from the expansion valve. I'm hearing the same thing, it works fine, and there is no leak.
Edit: If you do have to replace the evaporator, you're right, it's going to be fn expensive. Half the car has to be dismantled to get at it.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-07-2012, 02:29 PM   #3
87isee
My Ride: 87 325ic; 03 325i
That sound could be a sign that the system is a little low on refrigerant. If it gets low enough, you'll notice the air coming from the right side of the center vent is much warmer than that of the left. For a couple hundred bucks, a dealer will evacuate and recharge the system with a little dye added so they can check for leaks. Start with that.
87isee is offline   Reply With Quote
