Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 11-07-2012, 09:36 PM   #1
Jiggs46
My Ride: 01 325i
A big hello from PA!
Hello all! Have been scouring the forums for info the past couple days. Picked up my 01 325i with 112,00 miles the other day. I have been suffering the cold start rough idle and stalling and my google searches brought me here. Lots of great info!
Jiggs46 is offline   Reply With Quote
Old 11-10-2012, 09:32 AM   #2
3 3 0 C i
My Ride: 528xi
Hey welcome. My bimmer's from the PA.
These could be VANOS seals or might be fuel pump / filter. I'm about to do my fuel pump and filter; I'll let you know if it affects the cold starts.
2002 330Ci M Sport, 5-speed Manual
2013 528xi Premium, 8-speed Steptronic
3 3 0 C i is offline   Reply With Quote
Old 11-11-2012, 05:01 PM   #3
Jiggs46
My Ride: 01 325i
Hey I fixed the issues thanks to this great forum. Was throwing code for intake cps. Replaced that. Also replace the cvv lower drain hose. It was severed. Replaced lower intake elbow, and cleaned icv. DISA still had spring tension and flap was intact, so I cleaned and put back. The idle is perfect now. Thanks E46 fanatics!
Old 11-19-2012, 11:58 AM   #4
3 3 0 C i
My Ride: 528xi
Hey, just to let you know....
Replacing the fuel filter (and pump) has given my car a boost during gear changes. There was a nearly un-noticeable delay when accelerating again after clutching. The new filter and pump has helped a lot.
This morning was 37F, and it still sounded a little weird (maybe need to check the things you replaced, I already did the cps) but overall a lot quieter and smoother on a cold start.
Hope you're having good times w/ your e46.
Old 11-19-2012, 12:35 PM   #5
M-Spec Tuner
My Ride: 325i
Welcome! Great that this forum is of good use to you already...
'03 325i...Just getting started!
M-Spec Tuner is offline   Reply With Quote
Display Modes
