Why my crankcase vent hose has oil in it? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-08-2012, 04:58 PM   #1
farukh
My Ride: BMW 325i 2002
Hey guys!
Well, my car started smoking again! And it smokes the burned oil.
No, its not the VCG, VC. No, its not the oil separator. (although... read further please...)
However, when I removed the crankcase vent hose it had a little oil in it. Should there be an oil in there? Isn't it just for air? Not sure about it.
Also, obviously there was oil on spark plugs. Not in spark plug holes, but on spark plugs.
I did my oil separator couple months ago and it fixed my heavy smoking that I had when my car got warm, but now it start smoking a little again.
So my final two questions are: Should there be oil in the hose that goes from oil separator to the valve cover (is it normal)? And, what can be another reason, besides bad VCG, piston rings and bad oil separator... to burn oil?
I think I might even have another question lol since I just changed my oil separator and put brand new from the dealer... can the new one go bad so fast.. and if yes, why???
Thanks guys
farukh is offline   Reply With Quote
Old 11-08-2012, 07:49 PM   #2
farukh
Anyone!? I am confused! Everything points to the oil separator again.. but I just replaced it! And I should mention, that after I replaced it, the car was running perfect for couple months! No smoke! Until past few days
Old 11-08-2012, 08:10 PM   #3
My325XI
My Ride: 03 325XI Sprt Prem
When you changed out the oil separator, did you change out the related CCV hoses, dipstick hoses, etc... Could be a clog somewhere in the hoses.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 11-08-2012, 08:22 PM   #4
Barneyhyphen
My Ride: 2004 M3 Convertible
Check the rubber hose that comes off the bottom of the seperator is intact and not rotted away.
BH
Barneyhyphen is offline   Reply With Quote
Old 11-08-2012, 08:24 PM   #5
farukh
Yes! All the hoses from the oil separator were also new from the dealer!
Old 11-08-2012, 08:25 PM   #6
farukh
BH
I had that! But that was fixed together with the oil separator. Now all of that stuff is new!
Old 11-08-2012, 08:39 PM   #7
Barneyhyphen
The engine (2000 323, 147k) I just did the HG on was FULL of semi-solidified sludge/coal. Could the inlet on the side of the valve cover, to which the separator pipe attaches, be clogged with sludge?
Take a look at my "sludge?" posting from last month to get an idea what the inside of the top end COULD look like.
BH
Old 11-08-2012, 08:45 PM   #8
farukh
BH
My Valve Cover is also brand new... Just installed it couple weeks ago.
But, now that you mentioned the sludge... I am thinking: I did not do an oil change after I replaced my oil separator (even though my oil was not that bad, since I had it leaking and constantly refilling, BUT I several times used the crap that they sell in auto parts, that supposedly seals the leaks, which you add to your oil.) Do you think that might be the reason of my troubles? Can it clog up the hose? If it did, that freaking sucks! Because now I will probably have to replace the whole damn oil separator kit. And plus, I need to figure out the way to flush that crap out of my engine.
Old 11-08-2012, 08:54 PM   #9
jfoj
My Ride: 330CiC, M5, X5, E93
Your dipstick tube may be clogged up where the lower CCV oil return hose connects to it??
The original dipstick tubes were double walled near the bottom to allow the oil from the CCV to drain back and not interfere with the dipstick. This caused a lot of problems as this dipstick double wall would easily clog up.
You have 2 options if your dipstick tube is clogged.
1. Remove the existing dipstick tube and clean it out using wire, carb cleaner and compressed air.
2. Buy a new, replacement, single wall dipstick tube and also buy a new dipstick as some of the tubes differ in length. This new single wall dipstick tube is less likely to clog in the future.
Old 11-08-2012, 09:34 PM   #10
Zchild
My Ride: 2000 BMW 3XXi ZSP
I would check your DISA valve, a leak in that system will cause you burn oil and cause oil to collect in your CCV, I just changed mine for that very issue. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 11-08-2012, 09:34 PM   #11
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
this is normal.
your CCV is design to tackle blow by and the associated problems caused by blow by such as pressure in the crankcase. the high pressure will cause small amount of oil to move around the CCV but the CCV will drain that oil back into the dipstick guide and thus back to your oil pan. the excess air/fuel mixture will get redistributed back into the intake manifold and thus back into the combustion chamber. the CCV also have a check valve that prevent these flamable fumes to ignite backward toward the intake manifold.
so to make a long story short...CCV will always have oil (this is why they are also known as oil seperator). this is why you will see an oil catch can for after market CCV/PCV
the answer: yes there SHOULD be oil in that hose that connects to the valve cover to the CCV
Old 11-09-2012, 12:25 AM   #12
lcoleman
My Ride: '79 Massey Ferguson
Originally Posted by flashtwosix View Post
this is normal.
+1
OP, rings and valve stem seals are the only other logical things that would cause burning oil. Can you post a picture of your plugs? That is worth a thousand words.
Also, are you using oil?
Old 11-09-2012, 02:05 AM   #13
vimal32
My Ride: BMW E46 320i
Guys, this might seem stupid, but is there a way to test the CCV?
I know about the oil Cap removal test, i did it and my ccv seems fine from that test result - No weird noise and there is a slight suction.
Is there any other tests that can help rule out the CCV, like removing the crankcase vent hose from the top of the crankcase and driving around.
I know this isnt the ideal thing to do, but hey its a test, what could go wrong?
My logic is if there is a blockage somewhere related to the CCV or its hoses, by disconnecting the crankcase vent hose from the top, you will be relieving any pressure there is in the crankcase.
when disconnecting the crankcase vent hose, and letting the engine idle, should I feel any air coming out of the crankcase hole?
Ok, so maybe this test might have to be done for a longer term to see if it helps with oil consumption in any way.
your thoughts?
vimal32 is offline   Reply With Quote
Old 11-09-2012, 08:07 AM   #14
farukh
Got it! I will try to clean it up today! I very very thoroughly cleaned it when I was doing my oil separator DIY... But oh well, let see if that's the case.
What do you personally think could cause the clog ups? Maybe I should change the oil? Although, when I was replacing my VC, the oil in there seemed nice and clean. I will check my oil filter today as well.
Old 11-09-2012, 08:08 AM   #15
farukh
+1 for DISA valve, I forgot to mention that! BUT, I fixed my problem with the DISA several months ago too...
Old 11-09-2012, 08:10 AM   #16
farukh
this is normal.
Well, that kind of makes sense... But then why does it get on to my spark plugs? I will take a picture of them today... Although there is really nothing much to see, except the burned, all black spark plug (the part that screws in) with excess amount of oil on it. There shouldn't be any oil on the spark plug at all!
Old 11-09-2012, 08:11 AM   #17
farukh
Originally Posted by lcoleman View Post
+1
I will post the pics today! What do you mean by "am I using oil"? lol using oil for what?
Old 11-09-2012, 08:17 AM   #18
farukh
your thoughts?
Read this http://forum.e46fanatics.com/showthread.php?t=897616
This is a thread by jfoj! It helped me solve my problems with my oil separator. And my problems were horrible!
First of all, my car was driving like crap for several months because I couldn't find a vacuum leak... Thanks to jfoj, I found out that the hose from my oil sep to dipstick is broken in half. Also, after I replaced that hose, I found out, again thanks to jfoj, that my oil separator is faulty, because everytime my oil got boiling the oil sep was sending the oil (and ALOT of oil) somewhere, where it shouldn't have, and my car was smoking... Imagine the worst possible amount of smoke coming out of the exhaust.... It was smoking worse then that!
So really, besides the small symptoms... if your oil sep goes bad, you will know it lol
I don't think you car really test it by disconnecting hoses or opening the oil cap... BUT, if you looks at it and looks messed up and oily like my did, probably its time to change
Old 11-09-2012, 09:26 AM   #19
jasonbimmer
My Ride: 2001 BMW 330xi
well that means the engine is burning oil excessively. either piston rings are leaking very bad (compression test), or the oil is getting into the engine from the intake.
the hose has oil in it is normal because thats what it's for - collecting oil vapor.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-09-2012, 10:09 AM   #20
lcoleman
Is the engine burning/consuming the oil. ie. does the level on the dipstick go down.
