///M3 Forum
Old 11-08-2012, 08:22 PM   #1
MTREEZY
My Ride: 05 M3
Grinding Noise from Rear of car
So I think that the problem is that i need to change the differential fluid but i'm not exactly sure. I've done it before but this would be the second time i'd have to do it and I have only 48,000 miles on my 2005 Bmw M3. I have a video clip of the noise is making. If anyone can shed any more light please feel to chime in.
MTREEZY is offline   Reply With Quote
Old 11-08-2012, 08:42 PM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
I like the comment in the video "could be brake dust." Haha, definitely not. What it does sound like is the brake dust shield rubbing on the rotor as the car moves. Have you checked it to see if it is contacting the rotor? Maybe a rock lodged between the shield and rotor?
If your diff was making that kind of sound, your car more than likely wouldn't be moving.. And if it actually ends up being the diff that is making that noise, changing the fluid in the 'new replacement diff' is probably what you should do.
Seriously though, check the dust shield for debris/warp.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-09-2012, 05:15 AM   #3
lucky_doggg7
My Ride: 2005 M3
Dude - that is a small rock stuck between the rotor and the dust shield that is located on the backside of the rotor, or it is the rotor rubbing against aforementioned dust shield. I had this same noise after haphazardly cutting (and I must have inadvertently bent the dust shield) so that it rubbed against the rotor when I installed my Brembo rear bbk. Remove the rear wheel, get a long screwdriver and insert it between the rotor and dust shield, then perform a prying motion all around the rotor's perimeter to move the dust shield away from the rotor.
Old 11-09-2012, 06:19 AM   #4
HiHoBrian
My Ride: 05 M3
This sounds exactly right to me. I have had this happen two or 3 times. Twice I was able to reach through the wheel and push on the shield and hear the rock drop out. Another time it was really jammed and I had to pull the wheel off.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 11-09-2012, 06:57 AM   #5
Slyde
My Ride: 2001 M3 TiAg
Could also be something in the e-brake drum. It might be worthwhile to take it apart, clean it up a bit, and adjust anything (I suggest doing so without disassembling the drum pads from their mounting because the springs are pretty stiff to reattach, but doable).
Slyde is offline   Reply With Quote
Old 11-09-2012, 08:31 AM   #6
S54Dan
My Ride: '05 M3 '03 ZHP
Sounds like a rock in between your brakes
Edit: oops just saw it was posted above
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 11-09-2012, 01:55 PM   #7
MTREEZY
My Ride: 05 M3
Thanks for all the help guys. I'm going to get the car up on the jacks and check the shield for debris as suggested and will report back. Hopefully that is all that is..
Old 11-11-2012, 02:38 PM   #8
MTREEZY
My Ride: 05 M3
So no debris has fallen out of the rotor/dust guard. But when fiddling with it, it did make a noise that sounded like the dust guard was bent back into place.. I have no heard any further noise. Thanks again
Old 11-11-2012, 06:35 PM   #9
Ballstowalls
My Ride: 05 e46 m3 vert
Lmfao brake dust !!
Ballstowalls is offline   Reply With Quote
Old 11-14-2012, 09:34 PM   #10
dilburt
My Ride: 2004 M3
Rear brake rotor shield
If I recall correctly, there was a service bulletin regarding e46 rear rotor shields around that model year. It was related to heat causing the shields to warp and contact the rotor which made a grinding noise like this. I believe they issued a replacement shield part that solved the problem.
D
dilburt is offline   Reply With Quote
