Sponsored by BimmerWorld
Old 11-12-2012, 09:27 PM   #1
jlgone
My Ride: 2002 330 CiC
Coilovers that can be raised to stock sport height?
What coilovers can be raised to a height that is close to stock sports suspension when desired?
I see drops starting at - 1 inch for PSS etc. but don't know if this drop is from BMW OE non-sport height or sport height.
What coilovers can be raised the most?
jlgone is offline   Reply With Quote
Old 11-13-2012, 11:18 PM   #2
fth001
My Ride: 325i, e36m3, s13
I think almost every coilover can go pretty close to that height and adjusted about 3".
fth001 is offline   Reply With Quote
Old 11-14-2012, 06:25 AM   #3
jlgone
That's what I thought too but in researching it seems most do not have as big a big range as I thought, e.g., PSS lists 30 to 50 mm drop (1.0 - 1.75 inches)' KW v1 40 to 75 mm drop, h&r 1.0 - 2.75 inches. Also they all list 1.0 inches as the minimum drop. Sport is supposed to be about 15 mm (0.6 ") lower than non-sport. Ground control adapters are listed at 0 - 1.75 inches, but so far they are the only thing I see that s capable f being raised up to stock height if you want to. I am not interested in slamming the car; I just want to be able to go from a moderate drop (ProKit) to stock sport/ZHP height.
If I can't do that little bit of adjustment why bother with coilovers? There are plenty of posts on how low they'll go but nothing on how high!
Anybody have PSSs or others raised to close to stock height in winter, etc.?
