Sponsored by BAVSOUND
Old 11-09-2012, 10:53 AM   #1
RJDaly28
My Ride: 2002 M3 SMG
Dynavin Engine Noise with RCA out....??
Hello all. I'm in the middle of having an amplifier and new speakers installed in my car right now, and my installer is getting engine noise through the RCA outs on the Dynavin.
He's tried an outside power source, new ground, multiple amplifiers, RCA's outside the car so there cant be interference, etc and seems to have eliminated any source of the problem except for the Dynavin.
It's not terrible, but it's also not right. Has anyone else run into this issue? We're sort of standing here shrugging our shoulders and it would be great to get my car put back together.
RJDaly28 is offline   Reply With Quote
Old 11-09-2012, 05:15 PM   #2
opti
My Ride: 2004 330xi
Am I reading this right, you basically said it's the Dynavin, right? What is changing before vs after? Are you going from speaker level to RCAs or have you been using RCAs from the Dynavin all along?
opti is offline   Reply With Quote
Old 11-09-2012, 05:37 PM   #3
markusmarkus
My Ride: 2001 330Ci
It soundalike you've got a grounding problem. Make sure that your installer is not using the battery ground lug as a audio system ground. The head unit should use the same ground as the original head unit. The amps, etc. should use the original oem amp ground above and slightly forward of the oem amp's location.
Old 11-09-2012, 05:40 PM   #4
RJDaly28
I had been using the speaker level outputs to the H/K amp. Didn't have any noise. Switched to the RCA outs to a Kenwood 5-channel amplifier and now I have a hiss at zero/low volume and a slight engine whine at low volume.
Old 11-09-2012, 05:44 PM   #5
RJDaly28
I misspoke. He is using a new ground, and the head unit is grounded to the same place as the amplifier.
Old 11-09-2012, 05:48 PM   #6
opti
My Ride: 2004 330xi
Have you used different RCAs while everything else is the same? (RCAs with Dynavin, Kenwood amp, same everything else) Are you using your stock wiring for RCAs?
Old 11-09-2012, 05:51 PM   #7
RJDaly28
I was using the stock wiring when it was hooked up to the stock amp. Now I'm using RCAs. The installer tried several sets of RCA cables - same result every time.
Old 11-09-2012, 06:03 PM   #8
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
if you turn the gain down some do you still get sufficient volume?
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 11-09-2012, 10:58 PM   #9
RJDaly28
I had my installer button everything up since I needed the car back so I haven't tried that myself. I'm thinking there should be a little room to do that. This system is incredibly loud to my ear. Beyond 40 is ear splitting.
(It sounds amazing BTW)
The noise needs to go though, it is quite noticeable at zero or low volume.
Old 11-09-2012, 11:28 PM   #10
J&T Distributing
My Ride: BMW
Yep, your gain is to high....
Old 10-16-2013, 03:01 PM   #11
albarran9
My Ride: E46, E53, E90
Im having the same trouble except mine is still doing it with the gain turned all the way down. If I use an iPod as my source using the same RCA cable I don't get it or when the car is not on. I've tried several RCA cables and ground spots. The static is annoying. I don't get get it though when I use my AudioControl LOC, but the bass isn't as good and the sound is muffled.
albarran9 is offline   Reply With Quote
Old 10-24-2013, 12:16 PM   #12
J&T Distributing
My Ride: BMW
In general, If you run aftermarket amps, processors, etc... in an E46 its CRITICAL that you ground your trunk components to the stock grounding point in the trunk, left rear wheel well, its a stud with a bunch of the stock brown ground wires going to it. Grounding your amps etc... to the battery creates a difference in resistance to ground between the head unit and amps, known as a "ground loop"....also known as noise.
