Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 11-09-2012, 12:58 PM   #1
o22ripper
My Ride: 2002 E46 330i
FS: Front Control Arm Bushings & Others
Unfortunately, I'm no longer an E46 owner. I just traded it in for a new IS350 last weekend.
That being said I have a few parts for sale that I purchased in hopes of repairing the car. It was a 2002 330i.
I have brand new, still in the package front control arm bushings ordered from ECS Tuning: http://www.ecstuning.com/Search/31126757623u/ES1899439/
Asking price: $90 SHIPPED SOLD SOLD SOLD
Other parts I have:
-ECS Aluminum Water Pump Pulley ($30 SHIPPED)SOLD SOLD SOLD
-Valve Cover Gasket Set: http://www.ecstuning.com/Search/11129070990/ES18833/ ($30 SHIPPED) SOLD SOLD SOLD
-Mann Fuel Filter
-NGK Spark Plugs SOLD SOLD SOLD
-Hydraulic Tensioner Conversion Kit
-AC Belt SOLD SOLD SOLD
Thanks! Let me know if you have interest in any other parts...._a_
o22ripper is offline   Reply With Quote
Old 11-18-2012, 09:51 PM   #2
o22ripper
Bump
Old 11-20-2012, 01:11 AM   #3
o22ripper
Bump
Old 11-20-2012, 07:29 AM   #4
amanamanxxx
My Ride: 325i
Is the flitter new ? and text me with the prices 1315 417 0365
amanamanxxx is offline   Reply With Quote
Old 11-20-2012, 06:19 PM   #5
o22ripper
Hey Amanaman -
The filter is BRAND new, never been opened:
-Mann Fuel Filter....Part #:13-32-7-512-019-M67 ($55 SHIPPED)
Let me know if you're interested.
Thank you!
Old 11-21-2012, 05:09 PM   #6
Erikx559
My Ride: 2002 325i
Thanks o22ripper. I received my gasket today no problem. Fast and easy member to work with. Any member wondering, yes he is legit despite his post count.
Erikx559 is offline   Reply With Quote
Old 11-25-2012, 05:36 PM   #7
o22ripper
Bump
Old 11-29-2012, 01:42 PM   #8
joeyrevolution
My Ride: E46 325i
do you still have the control arm bushings? and will they fit a 325i? thanks!
joeyrevolution is offline   Reply With Quote
Old 11-29-2012, 03:24 PM   #9
o22ripper
Hey Joey -
It looks like it will fit according to ECS. Check it: http://www.ecstuning.com/BMW-E46-325...ngs/ES1899439/
Same part numbers. Let me know and I can ship it off tomorrow!
Thanks!
Old 12-02-2012, 06:21 PM   #10
jwebb
My Ride: 325i
do the control arm bushings have to be pressed in? or the old ones cut out? I need a set, just curious on the type of job it is.
Pete
04-BMW 325i lady's car
69-Chevy C/10 my project
97-Ford Ranger ridin on 35's
jwebb is offline   Reply With Quote
Old 12-03-2012, 04:25 PM   #11
o22ripper
Hey Pete -
The bushings are already pushed into a new carrier. Here is a DIY guide I found online:
http://shadetree-mechanic.blogspot.c...m-bushing.html
Old 12-04-2012, 07:44 PM   #12
jwebb
My Ride: 325i
I appreciate the information. I had a wheel bearing go out not long ago. Had it replaced, it didn't last a month. I found out the bearing needed pressed on. So I bought a used hub bearing assembly. All I had to do was unbolt the tie rod and ball joint. long story short, It started the growling noise again. This time, there's no up and down movement, but enormous side to side, tie rods are tight. With a little more looking I seen all the movement is coming from those bushings. They most defiantly need changed. I'm hoping that's causing the growling noise. I'm going to have to change the ball joint and tie rod also. Because of my lack of knowledge, I damaged the rubber boots when I changed out the wheel bearing assembly. live and learn
Pete
Old 12-07-2012, 03:52 AM   #13
o22ripper
No problem man!
