Maximum PSI/Technique Tuning Stock DME Tuning Solutions - Single Bank Conversion - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-22-2013, 03:14 PM   #1
luke@maximumpsi
Past Site Sponsor
My Ride: 750hp E36 NickG Tune
Hey guys,
As more stock DME tuning solutions become available for the turbo E46 M3 world, a few questions have been asked regarding the way we choose to tune the MSS54 ECU compared to others.
I wanted to start a thread outlining one of the major tuning hurtles faced by our team, more specifically Nick G, and how we choose to find a solution to the problem rather than try and work around it.
From the factory, the MSS54 ECU controls the engine's fueling as if it was actually 2 separate 3-cylinder engines (bank1 and bank2). This was possible because cylinders 1-3 had their own dedicated oxygen sensor, and cylinder 4-6 had another sensor. When installing a single turbocharger, the exhaust gasses from all 6 cylinders get combined together. Merely installing both pre-cat sensors into the downpipe will not work. The reason is because the ECU 'samples' the oxygen sensor signal at finite points in time; it first measures the bank 1 sensor, then 10 milliseconds later, it measures the bank 2 sensor. In those 10ms, the output of sensor 2 will vary SLIGHTLY from that of sensor 1. The ECU will interpret that slightly different reading from sensor 2 and calculate a different fuel modifier (aka, integrator) than bank 1. The result will be a different mixture in bank 1 than in bank 2. Over time, the two banks will become out of sync. One bank will end up being 25% rich, and the other 25% lean. The AVERAGE will be 0% from stoich, so the ECU thinks everything is fine, but clearly it is not, and the engine will run poorly.
There are a few ways to try and manage this exhaust gas integration:
1) Tie both bank 1 and bank 2 oxygen sensor wires together.
This won't work as the original problem still exists; the sampling of the bank2 line is still later than the bank1 line. This ends up causing the same problem as described above.
2) Disable lambda control in the ECU
While this method will make the ECU happy, it is clearly not the 'right' solution. Disabling the lambda control has many more CONS than PROS. The cons are increased fuel consumption, increased emissions, inability of the ECU to detect and compensate for engine and sensor wear, automatic failure of emissions testing, and on and on. Frankly, there really aren't any pros.
3) Rewrite the ECU's control code to work with 1 bank
This is the solution Technique Tuning implemented. The software was rewritten to work with only 1 pre-cat oxygen sensor, and 1 post-cat oxygen sensor. The original bank 2 sensors can be completely unplugged and eliminated from the vehicle. No simulators or resistors need to be installed due to their absence. No fault codes will be set or stored due to the missing oxygen sensors. The ECU will base fueling for all of the cylinders on the single oxygen sensor installed. There is no chance of any contention between bank1 and bank2 since the ECU now sees the engine as one single bank.
You will notice that the exhaust that comes with our kit will only have with 2 ports for the factory O2 sensors (3 if the customer needs an aftermarket O2 sensor). In our installation instruction you will aslo find that you unplug and remove both bank 2 O2 sensors.
Here are some pics to give you an idea of what I am talking about. Feel free to ask any questions you have!
-Luke
luke@maximumpsi is offline   Reply With Quote
Old 01-22-2013, 03:50 PM   #2
WALKD U
My Ride: Just Fast!
Nice! I can't wait to get my kit...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 01-22-2013, 04:10 PM   #3
02black330ci
My Ride: spaceship
Again, that is some SOLID dev work from Nick G!! Few questions.... What happens to the EGT sensor from Bank 2? Are you guys planning on eventually providing higher horsepower stages with the DME tune, ie 650 whp, 750 whp, etc? Any way to adapt (or future plans) E85 to the factory DME tune with an addition of an ethanol content sensor as real time % feedback?
Again, keep up the great work!!!
02black330ci is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-22-2013, 04:33 PM   #4
MachRc
is divorced
MachRc's Avatar
My Ride: 2003 Technik S1 M3
thanks for the indepth explanation!
"Can it be, we've run out of time? You're alive.. ohhh? In these streets we living to die. When it's your time, you will know..
..cause it ain't hard to tell. "
MachRc is offline   Reply With Quote
Old 01-22-2013, 04:48 PM   #5
Think0rz
My Ride: 05 AW M3
While I cant comment you are definitely in sync with the guys at the shop. E85
Think0rz is offline   Reply With Quote
Old 01-22-2013, 05:00 PM   #6
02black330ci
My Ride: spaceship
Old 01-22-2013, 05:20 PM   #7
E85head
My Ride: E46 M3
This!
E85head is offline   Reply With Quote
Old 01-22-2013, 06:43 PM   #8
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Did you win the lotto or something?
Old 01-23-2013, 11:33 AM   #9
luke@maximumpsi
Past Site Sponsor
Guys,
As Dexter has precluded to, we are currently working on several higher octane fueling options with the shop turbo M3. One of which is e85. There is a lot of risk invoved with offering a solution to pump "e85" to the masses as the ethonal content can vary significantly from day to day and pump to pump. Once we feel confident with the results with the shop car, we might offer them as an upgrade path to the current offering.
Old 01-23-2013, 02:04 PM   #10
FragNasty
My Ride: Car
This is probably a newby type question to you guys but...
Why not install the pre-cat O2 sensors pre-turbo and go with a twin-scroll setup where each bank takes measurements from a scroll fed by 3 cylinders? Mike mentioned that it was not possible for some reason but never explained why.
Obviously the pos-cat O2 sensors are going to take measurements from exhaust that is a mix of the two pre-cat scrolls. But if the DME relies on pre-cat sensors for its AF calculations then that shouldn't be a problem.
If memory serves, the N54 (the first generation twin-turbo E9x 335i engine) is a twin turbo that managed to keep the two banks separate all the way through the cat.
The N55 (the second gen twin-scroll 335i engine) has a twin scroll turbo. It appears to have only a pair os sensors, one pre-cat and one pos-cat so BMW went the route that Nick choose for this kit it seems. Is that right?
Thanks in advance.
Originally Posted by luke@maximumpsi View Post
Hey guys,
-Luke
FragNasty is offline   Reply With Quote
Old 01-23-2013, 07:04 PM   #11
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Pressure affects O2 sensors...or more specifically the readings. Sticking them pre-turbo would skew the response.
If you look at the newly introduced McLaren ECU used by Nascar, they have an external 4 channel Lambda controller used for each cylinder bank with a pressure sensor integrated. Being that the Nascar engines have a fairly free-flowing exhaust....and they have chose to go this route...kind of highlights the effect. If I was to try and run the setup as you've suggested, I would use the AEM/Nascar box as described above.
Old 01-23-2013, 08:59 PM   #12
FragNasty
My Ride: Car
Thanks.
It makes perfect sense now. In a previous thread you touched on something along these lines as I recall now.
Old 01-23-2013, 09:09 PM   #13
mike@maximumpsi
My Ride: 02M3T
Beat me to it. The N54 has two completely separate banks, and even still, the sensors are all downstream of the turbos. I have not looked at the N55 layout but I assume it has a single pre and post cat O2 sensor, and both are after the turbo.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 01-24-2013, 02:41 PM   #14
02black330ci
My Ride: spaceship
Guys,
Luke thanks for the response!! Keep the info coming and keep up the good work guys.
Old 02-19-2013, 01:12 AM   #15
BrianSpilner
My Ride: Max PSI Stage 2
How is it possible to tune the OEM DME for E85 when the percentages of Ethanol at each pump is different? I am assuming that a flex fuel sensor needs to be integrated somehow into the DME?
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 02-19-2013, 07:14 AM   #16
mike@maximumpsi
My Ride: 02M3T
Correct
Old 02-19-2013, 07:39 AM   #17
E85head
My Ride: E46 M3
Eta? ^
Old 02-19-2013, 04:31 PM   #18
luke@maximumpsi
Past Site Sponsor
We are currently working on the calibration with an upgraded fuel system as we speak! There is a good deal of R&D that is going to be required to make the E85 option commercially available. I would assume the 109 calibration with switchable maps will be available prior.
Last edited by luke@maximumpsi; 02-19-2013 at 04:32 PM. Reason: Auto-save 1361309520
Old 02-19-2013, 04:37 PM   #19
E85head
My Ride: E46 M3
Are you certain that the stock DME is capable of supporting a flexfuel sensor? Or are you looking at other options?
Old 02-19-2013, 05:01 PM   #20
luke@maximumpsi
Past Site Sponsor
We are confident! Only the stock DME will be used!
