Old 11-09-2012, 06:52 PM   #1
f4n4tik
My Ride: M-Sport 320Ci e46
Rough idle, rough ride. Need help!!!
So this morning I'm driving to work, I'm sitting at the lights and my car begins to shake pretty badly. It's idling very rough when it's in Drive and Reverse when I have my foot on the brake, also idles in Neutral and Park but not as rough. When accelerating there's a slight loss of power and continues to get that same rough feel as when it's stopped. Not a clue what it could be, there is no warning lights on the dash at all?
Thoughts anyone????
f4n4tik is offline   Reply With Quote
Old 11-09-2012, 06:54 PM   #2
f4n4tik
Oh and it's 2004 320ci with the m-sport package.
Old 11-10-2012, 10:05 AM   #3
Sean172
My Ride: 03' 330i
Rough Idle
I had the same problem in my 03 330i, after a ton of work I narrowed it to vacuum lines broken, one behind the Mass Airflow Sensor which leads to the fuel filter, and another on the air pump on the right front of the engine and wraps around the back of the engine. If that doesn't work check our youtube videos about replacing the oil seperator which is crankcase ventilation system which is an 8 out 10 on the DIY difficulty scale, it works wonders. You have to replace the unit and all the hoses, about $160 in parts. It is buried under half of the crap on the left side on the engine. They are known to go bad around 90k miles. If you get lean engine codes that is the tip off that you have vacuum and oil seperator issues. Good Luck
Sean172 is offline   Reply With Quote
Old 11-11-2012, 02:37 AM   #4
f4n4tik
Alright thanks for the advice dude, I'll check out those few things tomorrow.
