Old 11-19-2012, 07:14 AM   #61
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Sound Performance View Post
We have done some of that. Jason reported that taking off the HPF intake and replacing it with a 4" setup netted him over 50 hp!
Would that have more to do with exceeding 125m/sec with a 3" inlet pipe, than the manifold/plenum itself?
Obviously running large pre-manifold pipe will affect transient response...so it's a trade off with response versus peak power.
We have both measured ex back pressure at the turbo. It is not all that ridiculously high actually but that does not tell us the entire story in a log manifold as because the turbo sits near the rear and the first 5 runners all merge together, there may be high BP at the front cylinders.
Really good point, and pretty hard to measure without high speed sensors that would catch the dynamic response. I've looked into this from a response perspective, and the only sensors fast enough to measure this cost $1100-$1300 each depending on the range. Then you have to be able sample higher than Nyquist frequency...which is well above what most motorsport data loggers are capable off. Basically...you're into lab-grade equipment to watch this properly in real-time.....
Total cost including the logger, analysis software, and sensors would be about $11-12k. Pretty hard to build that cost into a manifold design unless you are selling a lot of them. (Or it's for a Motorsport project) Maybe FSR could comment on this?
Old 11-19-2012, 12:14 PM   #62
FragNasty
My Ride: Car
Please excuse the layman question: What is special about the 125 m/s intake speed?
By this stage our test setup should be on an engine dyno.
I presume that the higher (or lower) than Nyquest frequency would result in a type of "multi-scan" type sensor strategy taking samples at discernible crank angles that would later be compiled into a high resolution chart based on several crank turns worth of samples?
The presumption, of course, is that the engine operation is constant during the crank turns whose samples are utilized and that can only realistically be approximated with an engine dyno.
IF that is true, then the actual cost of obtaining equipment for these types of measurements could likely be significantly higher. What about subcontracting to a firm that already has the lab and sensors? Does FSR have access to such a lab?
FragNasty is offline   Reply With Quote
Old 11-19-2012, 12:56 PM   #63
InDiGlOM3
My Ride: HPF M3 stg 2.5
I have an engine dyno no sensors of those types thou.
Sent from my PG86100 using Bimmer App
Old 11-19-2012, 02:55 PM   #64
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It's the approximate velocity where you start to see flow resistance increase exponentially when compared to mass flow; commonly known as the choke point.
No...$12k would do it, and you could use a chassis dyno...but it makes it a lot easier to experiment with different parts on an engine dyno. That is unless you had your hands on 4stHEAD.....
Old 11-19-2012, 05:47 PM   #65
E85head
My Ride: E46 M3
Can you tell us more about this turbo kit? Does it need an oil scavenge pump?
E85head is offline   Reply With Quote
Old 11-19-2012, 06:10 PM   #66
Alex@FSR
Past Site Sponsor
My Ride: E46
The guys are doing lots of testing with a variety of sensors and logging using some very fast pickups. We aren't just going to throw parts, boost, or nitrous at it to make a number.
The base kit is getting close to being ready. We'll show our oil system once we know it is 100%.
We're putting our heads together with SP and you can count on great results!
Thanks for all of the interest!
Alex@FSR is offline   Reply With Quote
Old 11-20-2012, 12:24 AM   #67
6spd_legend
My Ride: acura legend 6spd
Cant wait for this....
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 11-20-2012, 11:14 PM   #68
FragNasty
My Ride: Car
Interesting.
Thanks for your valuable insight!
Old 11-29-2012, 01:05 PM   #69
Reid@SP
Regional Sponsor
Reid@SP's Avatar
My Ride: Toyota Supra
Send a message via AIM to Reid@SP Send a message via Yahoo to Reid@SP
Originally Posted by E85head View Post
Has this system become true plug and play now? So that an average+ wrench turner can hook it up?
A system with this many capabilities will never be completely plug and play.
Hi FSR guys!
Sound Performance
Shop (630) 893-5002
Cell (847) 363-3139
reid@spracingonline.com
**PLEASE DO NOT PM ME!! Please email me for inquiries/communicaton**
Reid@SP is offline   Reply With Quote
Old 01-08-2013, 02:02 PM   #70
E85head
My Ride: E46 M3
Bump for update!
Old 01-13-2013, 02:03 PM   #71
d'ray18
My Ride: E90 335
Oh wow, welcome! I'm looking into Cobb so great to know you Protune. Can you tell me what mods that 335 has?
2008 E90 335i
d'ray18 is offline   Reply With Quote
Old 01-13-2013, 05:47 PM   #72
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I stopped by FSR yesterday. I'm not allowed to say anything.. but I will say this... if you like stealth and clean installs.. I've never seen one as clean as FSR's to date.
Old 01-13-2013, 06:57 PM   #73
Commanderwiggin
My Ride: 900rwhp Turbo M3
Great to hear! I'll be going for a visit end of Feb
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 01-13-2013, 07:19 PM   #74
dallasberry
My Ride: ///M3
Take me with you!!!
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 01-13-2013, 07:29 PM   #75
Commanderwiggin
Originally Posted by dallasberry View Post
Take me with you!!!
Book the tickets ...then we can go to Disneyland!
Old 01-13-2013, 08:29 PM   #76
dallasberry
My Ride: ///M3
Wish I could buddy lol, I gotta save money for Mfest
Old 01-14-2013, 02:32 PM   #77
Dreikraft
My Ride: slow m3
lol, you getting new engine management?
Dreikraft is offline   Reply With Quote
Old 01-14-2013, 03:11 PM   #78
Commanderwiggin
We'll have to see Doubtful as I pretty much don't want to deal with ProEFI stuff as I have yet to see it at the level I want it...FSR however seems like they have their **** together. I'm holding out for the Infinity...I hope it's everything I want and more but I'll still hold my candle in the dark...waiting.
Old 02-18-2014, 05:01 PM   #79
6spd_legend
bump!
2001 LSB M3 Coupe
