Australia
Old 11-10-2012, 01:07 AM   #1
f4n4tik
My Ride: M-Sport 320Ci e46
Rough Idle and Drive, Help!?!
So this morning I'm driving to work, I'm sitting at the lights and my car begins to shake pretty badly. It's idling very rough when it's in Drive and Reverse when I have my foot on the brake, also idles rough in Neutral and Park but not as bad as D and R. When accelerating there's a slight loss of power and continues to get that same rough feel as when it's stopped. Not a clue what it could be, there is no warning lights on the dash at all? Maybe spark plugs need replacing?
Thoughts anyone????
f4n4tik is offline   Reply With Quote
Old 11-10-2012, 04:25 AM   #2
gueste46
Banned User
similar problem last month. Replaced plugs, coils and fuel filter. Good as new.
gueste46 is offline   Reply With Quote
Old 11-10-2012, 09:56 AM   #3
Kstrooch
My Ride: 325ci
Mine was doing the same thing. Ended up being the airflow sensor metre.
Kstrooch is offline   Reply With Quote
Old 11-10-2012, 03:18 PM   #4
Honro
My Ride: M3 E46
My first guess would be the coil packs. But always easiest starting with the simple stuff like your Airflow sensor - just pull it out and spray the mass air flow cleaner on it. If you are mechanically adept, then you can follow this diy on the coil packs;
SOLD - 2002 M3
- MOD LIST -
- ESS VT550 SUPERCHARGER @ 307rwkw | KW V2 Coil Overs | 20' Vertini Hennisy Wheels - 20x 8.5F & 20x10R -
Watch My S/C Install Vid Here: http://www.youtube.com/watch?v=guCnA...ature=g-user-u
Honro is offline   Reply With Quote
Old 11-11-2012, 07:02 AM   #5
BrownEye
My Ride: 318i
Mine shakes in idle due to the rear shocks being soft. Haven't got around to it yet
BrownEye is offline   Reply With Quote
Old 11-11-2012, 07:45 AM   #6
Dennis323
My Ride: 323ci
i had the same issue, got my spark plugs replaced, oils and filters, runs like a dream now
Dennis323 is offline   Reply With Quote
