Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 11-05-2012, 08:56 PM   #1
FoxEyes
My Ride: 04' 330i, 96' 328is
Exclamation Just installed OEM bmw alarm, no chirp, no blink, nothing different...
Just installed the entire BMW alarm with tilt, interior sensor, and alarm. Is there a fuse I need to add or check? Ive tried holding down trunk button, starting the car, etc... Im running out of things to do, I've checked all of the connections and them seem to be pretty simple.
FoxEyes is offline   Reply With Quote
Old 11-05-2012, 08:58 PM   #2
Andy2108
My Ride: E46M3E92M3'67Cobra
You may need to reprogram the car to enable the alarm.
Andy2108 is online now   Reply With Quote
Old 11-05-2012, 08:58 PM   #3
E40SICK
My Ride: 2001 330ci
you need to get the car programmed.
E40SICK is offline   Reply With Quote
Old 11-05-2012, 09:01 PM   #4
FoxEyes
So it would show 0 signs of working until reprogramming? I've read places that you get a chirp but none of the real alarm features until reporgramed
Old 11-05-2012, 09:02 PM   #5
pocojo68
My Ride: 2004/320i
You have to get it coded. Not just plug and play. PA soft or other programs or the stealer.
Sent from my LG-P500h using Bimmer App
pocojo68 is offline   Reply With Quote
Old 11-05-2012, 09:02 PM   #6
jfoj
My Ride: '06 330CiC, '03 M5
Programming.
www.xcar360.com and buy the BMW Scanner 1.4.0 for $32 shipped. Takes about 2 weeks from China.
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
Old 11-05-2012, 09:02 PM   #7
E40SICK
My Ride: 2001 330ci
you may have read the thread where someone added a small speaker to get the chirp sound just for letting the user know his/her car is locked.
Old 11-05-2012, 09:06 PM   #8
FoxEyes
Programming.
I'm going to go ahead and buy this, do you mind telling me what boxes to check / code
Old 11-05-2012, 09:07 PM   #9
E40SICK
My Ride: 2001 330ci
or why not find someone local to you? many members have the program to do so already.
Old 11-05-2012, 09:08 PM   #10
FoxEyes
I'm sure I can use this for other stuff / help my buds and $32 doesn't bother me
Old 11-05-2012, 09:23 PM   #11
cvx5832
My Ride: 325Ci, 325Cic, C300
I did it. Even that needs coding.
cvx5832 is offline   Reply With Quote
Old 11-05-2012, 10:51 PM   #12
haurelio
My Ride: 2001 bmw 325i
its gonna be under dwa module. check off everything under alarm. (visual,tones,etc).. there's a nice thread about that tool, you can get a pic from there,
Contact me if you need your att iphone unlock. Also can code your car
Old 11-06-2012, 07:17 AM   #13
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Screenshot of my checkboxes within the first page:
http://forum.e46fanatics.com/showthread.php?t=870745
Stiggles is offline   Reply With Quote
Old 11-06-2012, 10:32 AM   #14
FoxEyes
thanks fellas! fanatics are always a good help
Old 11-10-2012, 10:54 AM   #15
limpiabota809
My Ride: 330 XI
With this particular model the one from xcar360 do I need to solder anything to have it working properly coding and un coding like others out there?
limpiabota809 is offline   Reply With Quote
Old 11-10-2012, 10:57 AM   #16
Andy2108
Link?
Old 11-10-2012, 11:04 AM   #17
limpiabota809
My Ride: 330 XI
http://forum.e46fanatics.com/showthread.php?t=935082
Old 11-10-2012, 11:19 AM   #18
haurelio
check off tilt and motion sensor if you have them..
Old 11-10-2012, 11:21 AM   #19
Andy2108
Originally Posted by limpiabota809 View Post
thanks
