Old 09-22-2014, 01:22 AM   #1
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Lightening up the front of the car
Brainstorming...
Want to shed some weight off the front of the car. I don't want to remove necessary items (i.e. Headlights, etc).
So far I can only think of:
-M3 Kevlar Front bumper support (the aluminum non-m is pretty heavy actually) but I don't even know if it fits..
Throw some ideas out there if you've got them.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 09-22-2014, 01:44 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I run Hydrogen in all four tires, my un-sprung weight is almost nonexistent ! My only fear is when my brakes get real hot like when I'm in a maximum braking situation, All I can think about right then is Ferdinand von Zeppelin.
It's late,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 09-22-2014, 01:59 AM   #3
Llink78
My Ride: 2002 330i
Keep washer fluid low. Remove silly engine vanity covers. Lower plastic splash shield if your feeling adventurous. Fog lights. Buy those CF fenders from the china ebay mentioned in another thread.
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Llink78 is offline   Reply With Quote
Old 09-22-2014, 02:41 AM   #4
secono330ci
It's late,
Rob43
Damn you Rob, damn you
I removed all the plastic shields up front and even the headlight washer system But still even with that stuff and the secondary air pump removed, it's -15lbs. Plus the hood is another -30lbs.
I wish that damn m3 Kevlar bar would fit. Overall around -55lbs total with all that other stuff..not bad right?
Yea it's late, going to bed lol
