Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#21 |
Stay stock my friends!
I think Flash is right...if it was spinning freely entirely, you'd be leaking like a sieve.
I have to remember not to argue with you, Flash...at least not in the General forum! You'll be good, OP. Have another drainplug ready to go it.
#22 |
Gents,
Thank you again for imparting wealth of knowledge, ill update with pictures as soon as I can get her into shop Tuesday. Hopefully, the damage will be minimal(just a drain plug and 7qts if BMW5w30 oil =) |
#23 |
A shop? Uh oh! Did you do the oil change yourself that got you your spinning drain plug? If so, you could fix it easily yourself, you know.
#24 |
Haha to explain further, I meant to take it on auto skills shop on post. $2/hr for unlimited lift and tools is legit =)
#25 |
Banned User
#26 |
Good 'ol Fort Benning
#27 | |
#28 |
UPDATE: looks like inside threading is stripped. Took it to a shop and had the mechanic pull out the bolt for me, and he couldn't get it out either. , . Not good.
#29 |
Weld something that you can pull on to the bottom of the plug (like small metal rod or bar across the plug) Then turn the rod and pull on it at the same time to pull the plug out as you twist it.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. |
#30 | |
I hope he tried using pbblaster or something...welding is a decent idea, so is breaking off the end of the bolt and using an extractor/allen wrench inside. If a woman like Flash can break her bolt, I'd think your mechanic can. Tell him to stop being a girl and get it out...then quickly say you were kidding and that you'll give him a donut and coffee if he gets it out!
#31 |
For the peace of mind, I'd like to have an extra oil pan with me before I pull it. Once it's pulled, and the new drain plug does not fit/tighten, I'll be SOL and without s car until its fixed =(
#32 |
I still don't see how breaking the head of the bolt will help at all if the threads of the bolt are stripped. I think that method is to be used if the head of bolt is so stripped that a socket can't grip it. The point is that simply turning the bolt is not allowing it to back out, its just spinning. So whether you turn it with an Allen wrench or with the hex head it really needs to be pulled on while turning it to get it to back out.
I think your best bet is welding to it so you can pull on it while you turn it.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 11-14-2012 at 03:42 PM. |
#33 |
Been there done that .
You need a Tap and Die Set. Try this before foolishly buying a new oil pan.
![]() TC Kline | BMW Performance | Active Autowerke . |
#34 | |
At least there is still SOME relevant info around on this board ....
#35 | |
But, also this...the bolt, I believe Flash is right, is made to prevent it from stripping the threads by breaking before that happens. I wonder if it's still just the end of the bolt that's hung up and that they'd still find the broken part beneath. I don't know how stuff like this happens so often...if you start a bolt/nut by hand, you just don't strip it...and if you use the proper tool, you'd feel if something is wrong, before it goes very wrong. Good luck, OP...hope he got it out by now!
#36 |
Banned User
If your set on having a pan, I have one just pm me
#37 | |||
Banned User
See this thread for the same exact problem and the same exact "controversy/doubt/drama."
at the end of the day...the bolt is hollow and it was removed from using a ovesize allen key and hammer it in. it is like deja vu thread: http://www.e46fanatics.com/forum/sho....php?p=6895012 Quote:
#38 | |
If he busts the head off the bolt and then tries turning it with an Allen key then it still won't solve the issue with the stripped threads, it will still just keep spinning. The Allen key solution is for when you break the plug and need to get it out without removal of the pan. Not for when its stripped. (Just to clarify, he is still able to turn the bolt normally with the hex head, it's just spinning endlessly, the bolt is not broken)
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 11-14-2012 at 07:01 PM. |
#39 |
breakaway indeed
#40 | |
Banned User
sent from my dahc-6900 using Bimmer App Last edited by flashmeow; 11-14-2012 at 07:47 PM. |
