///M3 Forum
Old 11-10-2012, 10:43 PM   #1
Sdracer
My Ride: E46 m3 vert
Passenger door lock
Passenger door has to be Manually opened using the lever from the inside where should I start looking to fix ?
Sdracer is offline   Reply With Quote
Old 11-11-2012, 08:49 AM   #2
aznniche
My Ride: E36
remove door card. there's a cable on the door carrier that snapped loose - no tension and will not allow you to open from the outside. can fix by using ziptie back to carrier. search - there's a diy out there.
aznniche is offline   Reply With Quote
Old 11-11-2012, 03:04 PM   #3
Sdracer
I can hear the actuator work but it won't pot the door lock
Old 11-12-2012, 02:06 PM   #4
YGOSLO
My Ride: 03 CarbonSchwartz M3
Door lock actuator... Replaced mine right after I bought it. Pretty easy to do.
Full Black Interior For Sale
2003.5 Carbon Black/Imola Red ///M3 Coupe: Stock
2003 SVT Ford Mustang Cobra: Not Stock
YGOSLO is offline   Reply With Quote
Old 11-12-2012, 04:24 PM   #5
rblynn78
My Ride: 2002 M3 Vert SMG
Not Actuator
I had the same thing happen to me.
Good news - If you hear the actuator move but it doesn't unlock, but you can unlock manually with the handle, it is NOT the actuator.
Bad news - It is your GM, or General Modulator. Most likely something else will go weird soon, like driver side will not unlock every once in a while. About $500 to fix
2002 Porsche 996 C4 Cab (Sold, not missed :))
2005 VW Touareg V8
2002 M3 SMG Vert - Topaz Blue with Blue Top
Sharked, Supersprint Sport Exhaust, Euro Headers, Euro Section 1, Schnell Intake, BC Racing Coilovers (7kg/8kg) 19" BBS LM's, Carbon Front and Rear, Umnitza Angel Eyes, Smoked Side and Turn Signals, Coby Wheel and Shift Knob, RPI Intake Scoops
rblynn78 is offline   Reply With Quote
Old 11-13-2012, 10:26 AM   #6
YGOSLO
I'd have to disagree with the "Good News" portion of this. That is exactly what one was doing and a new door lock actuator resolved my issue. I can't attest to the "Bad News" part.
Nice Vert!!
Old 11-13-2012, 03:50 PM   #7
Rhumb
My Ride: 2001 M3 Coupe
Same problem, though I haven't fixed yet. My understanding: it's the door actuator whereas if it were the GM5 module, you'd get more random, weird schmidt going on.
YGSLO, how easy was it to replace? I sort of thought that, while technically pretty simple, it was actually a bit of a bear to get the old one out and the new one in due to tight clearances. True? Not? Your experience?
Rhumb is online now   Reply With Quote
Old 11-13-2012, 07:46 PM   #8
YGOSLO
I was intimidated at first, but I went off a DIY I got from M3Forums and it was actually pretty simple. Just read the entire DIY and follow other users' advice. Easily done in an hour.
http://www.m3forum.net/m3forum/showthread.php?t=242785
Old 11-13-2012, 10:58 PM   #9
aznniche
My Ride: E36
carrier cable is broken, dont' try the expensive route of actuators or gm5 before doing this simple fix.. here's a link: http://forum.e46fanatics.com/showthr...+carrier+cable
Old 11-14-2012, 12:43 PM   #10
rblynn78
Nice Vert!!
Thanks man!!!
Yeah, obviously thoroughly check to make sure it isn't the actuator. What I can tell you is I tried that first (as you should) and nothing. So I had to replace the GM which is expensive and sucks. Good luck!!!!
2005 VW Touareg V8
