Old 11-11-2012, 06:38 AM   #1
jimmy325i
My Ride: 325 sedan
exhaust fume resonating sound
What I originally thought was tappet noise, is actually exhaust fumes resonating in the exhaust manifold. This is accordaing to a BMW specialist. And I think I belive him because I came across a 330 and heard the same sound. However, is there anyway of damping or cancelling this horrible sound out?
jimmy325i is offline   Reply With Quote
Old 11-11-2012, 07:01 AM   #2
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
Sometimes the exhaust mani heatshield gets loose and rattles. This is the first I've heard of someone having an issue diagnosed as such.
A tape of sound would probably help...and so would you using a stethoscope or hose as stethoscope to isolate the sound.
Try techron to clean up the fuel system...make sure you're using a proper LL-01 oil. See if that gets you anywhere. Also, some just rip off the heat shield...but I'm not so sure about that myself.
GL...hth
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 11-11-2012, 08:08 AM   #3
HiHoBrian
My Ride: 05 M3
It may be the sound you hear is a leak AT the manifold,not IN the manifold. I know from installing headers on different cars and trucks when the gasket fails it sounds like a ticking valve or lifter. IMO your head to manifold gasket has failed. It's a pretty involved job. The only ways to correct it is to diy,or pay up for gasket replacement.
Edit: definatly confirm that it is a leak before pursuing a repair.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 11-11-2012, 08:13 AM   #4
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
Also check your spark plugs for any looseness. That causes a ticking sound too.
Old 11-11-2012, 09:13 AM   #5
jimmy325i
My Ride: 325 sedan
not the spark plugs for definate. Gonna look in to the other possibilities. Thanks
