Old 11-11-2012, 11:33 AM   #1
millerlite6633
My Ride: 2000 BMW 323ci
Grinding noise
Hey everyone so i recently started noticing that when i shut off my car it makes this grinding noise. The car is a 323ci with 157000 miles on it and the entire coolant system as been replaced not that that really matters i suppose. Only performance mods done are light weight pulley and nose cone other then that there is nothing done to the engine. Worst case scenario my engine be bad? Let me know what you guys think. Thanks for any help in advance.
millerlite6633 is offline   Reply With Quote
Old 11-23-2012, 02:19 PM   #2
eweis
My Ride: 1999 328i
Where is the noise coming from?
Is it in time with wheel rotation?
Does it happen, in or out of gear or with the brakes on or off?
eweis is offline   Reply With Quote
Old 11-25-2012, 01:29 PM   #3
millerlite6633
It only happens when i turn the car. The car is moving or anything. And it sounds like up in the engine bay. I suspect the alternator may be going bad now. Sounds like it comes from the general area.
Old 11-28-2012, 12:05 AM   #4
kcpkd
My Ride: BMW 330CI
Send a message via Yahoo to kcpkd
It's definately the alternator. I just brought my 330 in because everytime I turned the car off about 2 seconds later it would make a grind noise. Mechanic said alternator.
kcpkd is offline   Reply With Quote
Old 01-28-2015, 11:06 PM   #5
Morphy
My Ride: 02 325i touring
Have you sorted this ? I have a grinding like a metal slice noise stopped quick. Upon closer inspection with my mech it was actually the air box we tracked the noise to, once opened the seriously metal slice noise changed to an obvious squeak of suction
Morphy is offline   Reply With Quote
