Engine Bay Noise...Shocking - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-11-2012, 02:11 PM   #1
99_323i_Steve
My Ride: 1999 BMW 323i
Well, just a heads up on recent work done. Completed the full coolant flush and new thermostat,water pump, radiator, and ET around 85,000(I'm now at 101k).
Replaced vehicle with all new pulleys, belts, tensioners, and alternator also withinin the last 5k.
Sounds like it would be bad water pump bearings but...water pump is less than 16k miles used...so than i am assuming is it the water pump plastic pulley causing this noise? sounds almost like metal spinning oddly when sitting inside the car. Outside of the car its not as noticable because of the engine and belt noise.
When driving or accelerating it is noticable that its rotating faster, car has no over-heating issue as i followed mangos thread to the T on the coolant rebuild. any insight or people that have experienced something similar, feel free to chime in.
I've learned some people think their a mechanic when they can do their own oil change. Don't always believe what you read.
99 323i. Factory:Harmon Kardon Hi-Fi, Winter Package w/ heated sport seats, and Sport package with Sport steering wheel and Sport suspension.
Aftermarket: 16" rims, LED Angel Eyes, LED license plate lights, LED tails, LED depos, Black kidney grill, and DICE Aux jack input, 20% tint.
99_323i_Steve is offline   Reply With Quote
Old 11-11-2012, 04:39 PM   #2
shovelit
My Ride: 03 325xi and 04 330x
Possible alternator whine?
shovelit is offline   Reply With Quote
Old 11-11-2012, 05:55 PM   #3
99_323i_Steve
alternator whine is more of a high pitch noise I have more of a metal noise...
Sent from my SPH-M820-BST using Bimmer App
Old 11-11-2012, 05:56 PM   #4
99_323i_Steve
it sounds similar to the videos that have pulley issues but it's not the pulleys they are all brand new and so are the tensioners
Old 11-11-2012, 06:03 PM   #5
328iguy24
My Ride: e46 328i
I had a similar situation.. i replaced all the pulleys water pump and belts to find out that it was the actual tensioner its self. But you had stated you replaced it already.
heres a video of what mine sounded like.
http://www.youtube.com/watch?feature...&v=_EjWeGO4n6g
328iguy24 is offline   Reply With Quote
Old 11-11-2012, 06:17 PM   #6
99_323i_Steve
see that noise sounds almost exactly what it sounds like. Its odd tho because I've already replaced my mechanical AC tensioner but I don't have a tensioner for my serpentine belt...
Old 11-11-2012, 06:26 PM   #7
bratliff
My Ride: 330i
Are you sure? I have a 330 so I know our engines are different but if you don't have a tensioner how is proper tension maintained? This just sounds wrong but I don't know...
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 11-11-2012, 06:43 PM   #8
99_323i_Steve
I know what the tensioners look like the 1 I was looking for a do it yourself on how to remove the serpentine pulley I couldn't find a single picture that matched what my engine looked like because I didn't have any type of tensioner in place there I just had a bolt. I'll take a picture and upload it soon but it's kind of odd.
Old 11-11-2012, 06:50 PM   #9
Blocked Out
My Ride: Imola 330i M-Sport
Good luck trying to guess his problem without hearing it first
Original BMW Teile ///
IMG_1725
Old 11-11-2012, 06:56 PM   #10
99_323i_Steve
it sounds like every other pulley or belt issue that these cars have under the engine hood hence my post title.
Old 11-11-2012, 08:03 PM   #11
328iguy24
My Ride: e46 328i
If you seen my video and you said it sounds almost exactly like mine.. I would suggest replacing these parts, obviously figure out which tensioner you have.
Old 11-11-2012, 08:16 PM   #12
99_323i_Steve
Thank u those pictures are great. Could u audibly recognize the noise from inside? Looks like the bolt I was referring to is indeed the mounting bolt to a hydraulic tensioner. Common to have one of each type of tensioner in these early e46s? Because that is something I have NOT replaced. Any special instructions for installing. Any pre tensioning since its hydraulic?
Old 11-11-2012, 08:20 PM   #13
99_323i_Steve
also can i place a mechanical tensioner in place of the hydraulic or can they not be reversable for positions? my a/c pulley is mechanical and my serpentine pulley is hydraulic
Old 11-11-2012, 09:03 PM   #14
bratliff
My Ride: 330i
Ah! Turns out you were missing a tensioner. I knew I wasn't crazy.
'02 330i
'97 318i
'95 325 Vert
'76 280z
Old 11-11-2012, 10:37 PM   #15
99_323i_Steve
i see the hydraulic tensioner is more efficient and thats why BMW switched to them but is it possible to use a mechanical? seems so much user friendly than a hydraulic would be.
Old 11-12-2012, 02:13 PM   #16
99_323i_Steve
UPDATE: replaced the hydraulic tensioner today, pretty straight-forward job, the car does run and idle much smoother, the sound im listening for is still slightly there but definetely not AS loud as previously. thanks for those pics, they helped me identify that indeed while doing pulleys, belts, and tensioners that i missed one.
Old 11-12-2012, 05:40 PM   #17
328iguy24
My Ride: e46 328i
No problem. I replaced all mine and i still have a slight noise but thats because my acutal tenionser is going bad. I repaced everything else and now have to tear it back apart and replace that. lol
Old 11-12-2012, 07:16 PM   #18
99_323i_Steve
Haha it never ends!
Old 04-24-2013, 11:34 PM   #19
StrawburryYumYum
My Ride: 2000 323i
How do you install the mechanical one in place of the hydraulic? The mounting of the hydraulic is flat and the mechanical is not??? I'm having trouble installing my new mechanical tensioner assembly.
StrawburryYumYum is offline   Reply With Quote
Old 04-25-2013, 12:08 AM   #20
MJLavelle
My Ride: 2001 BMW 330ci
I don't think you can go from hydraulic to mechanical tensioners. You can only upgrade from a mechanical to hydraulic, via a kit. But a downgrade to mechanical is not possible, and not really worth trying.
