Old 11-11-2012, 11:18 AM   #1
330iBlue
My Ride: 05 330i
Explding pulley
I have an 05 330i and I have been hearing the pulley telling me time to change, but took too long to replace, so it sort of replaced itself by exploding.
I have two questions.
One. I have a hydraulic tension er next to the idler pulley. Do I have to change out the whole piece or can I just get away with unscrewing the pulling alone and replacing it.
Two. The AC tensioner? Can I do the same, just unscrew the middle bolt and replace it too. And is it the same size as the hydraulic pulley?
330iBlue is offline   Reply With Quote
Old 11-11-2012, 11:26 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You probably don't need to replace the tensioner itself...just the pulleys.
Do both tensioner pulleys and the idler pulley...and check all the other pulleys too...
Remove plastic cap, unscrew bolt (check the fitting...most seem to be T-50, but there are hex head bolts used also)
Pulleys for the hydraulic and mechanical tensioner are different...so if you have different tensioners, you have different pulleys.
Many threads with 'pulleys' in titles to help you get PNs...Autozone carries dayco pulleys, which are made by INA the OE manufacturer.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-11-2012, 11:45 AM   #3
330iBlue
My Ride: 05 330i
Thanks dmax.
Are aftermarket pulleys same as BMW pulleys? I see such a price difference?
Old 11-11-2012, 11:53 AM   #4
dmax
dmax's Avatar
OE is INA brand...available as Dayco pulleys from Autozone. Search thread titles for pulleys...many threads on them.
Mangofy your E46!
