Old 11-11-2012, 08:25 PM   #1
midnight325NYC
My Ride: 02 325i
Replaced rad now leak
Hey guys so my radiator had a slow leak and I bought a new behr one from bmaparts.com after seeing on here that it's legit. So my Indy put it in and said there's a leak where the lower rad hose connects to the rad. He tried to use sealant and all that but couldn't stop the leak. Now some of you may remember my random extreme over heat from a few months ago that turned out to be my upper rad hose (which was replaced) there's no problem with the connection of the upper to the rad but the bottom Jose is an issue.
Now the question is I know BMW hoses have the o- rings inside the hose itself, could it be that the lower hose is old and failing thus needing replacing or do you think it may be the rad?
midnight325NYC is offline   Reply With Quote
Old 11-11-2012, 08:55 PM   #2
TurnersInOz
My Ride: 2004 325i
Could be, but also check the temp sensor that is on the lower hose. This is a common point of leakage if not replaced.
If you wind up replacing the hose, make sure to also get a new sensor.
TurnersInOz is offline   Reply With Quote
Old 11-11-2012, 10:38 PM   #3
Mctwist77
My Ride: '99' BMW 323i
Replace hose, doubt radiator is faulty. I have a thread about just replacing the O ring look on my profile under statistics and go to threads started you should see it. Sorry i would give you the link but I'm on my phone.
Sent from my DROID2 using Bimmer App
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 11-12-2012, 08:17 AM   #4
midnight325NYC
My Ride: 02 325i
Thanks guys and yeah I was thinking about the sensor too I think I'm gonna swap the hose and sensor and see if that does the trick, will be back later with results
