Old 11-11-2012, 10:44 PM   #1
rebelwitoutacoz
My Ride: 2004 330ci
How do you take this clip off?
The clip under the headlight, i'm trying to get my fitment better on my bumper but i can't figure out how to unhitch it from the fender side.
rebelwitoutacoz is offline   Reply With Quote
Old 11-12-2012, 01:00 AM   #2
haurelio
My Ride: 2001 bmw 325i
pull from inner to outer..
Contact me if you need to unlock your phone.
Also can code your car
Old 11-13-2012, 04:50 PM   #3
BDUB328I
My Ride: bmw 328i S54 sedan (
there is a metal tab on your fender that slides into the outside of the plastic piece under the headlights. like haurelio said pull out the inner part then work toward the outer then pull the entire piece inward to get the tab out of it....i broke the plastic part where the tab goes on mine, so take your time
BDUB328I is offline   Reply With Quote
Old 11-14-2012, 02:00 AM   #4
rebelwitoutacoz
My Ride: 2004 330ci
thanks guys ^^
Old 11-14-2012, 08:02 AM   #5
GT172I
My Ride: M3 ZCP, 335is, 330ci
There's a little latch about halfway up that crack that hooks the two pieces together. Cover a flat head screwdriver in a rag or use a thin plastic trim tool to push in the crack from the side towards the hood roundel and the clip should pop loose
APEX ARC-8's | UUC EVO3 SSK | UUC TSE3-L | H&R sways
Stebel Truck Horn | Misc cosmetic stuff
GT172I is offline   Reply With Quote
