Old 11-12-2012, 03:34 AM   #1
Davo_330ci
My Ride: 2002 bmw 330ci
temp
hi i wanted to know if anyone can tell me how do you reset the outside temperature on a 2002 bmw 330ci
Davo_330ci is offline   Reply With Quote
Old 11-12-2012, 03:45 AM   #2
e46freak609
My Ride: 325 ci
is it giving you a weird temperature? maybe your ambient sensor is bad and need to replace it.. cheap fix sensor is located under your front bumper
e46freak609 is offline   Reply With Quote
Old 11-12-2012, 03:56 AM   #3
floydlloyd85
My Ride: 2002 318 Ci coupe
Yeah mines is missing. Must have fallen off. Keeps showing temps like -40 n stuff like that
floydlloyd85 is offline   Reply With Quote
Old 11-12-2012, 05:08 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If its -40 or 120 then you need to replace the sensor. Make sure you check the wiring first.
Old 11-12-2012, 10:18 AM   #5
Davo_330ci
mine is sayind + 122
Old 11-12-2012, 10:21 AM   #6
WDE46
My Ride: '13 128i, '04 330Ci
Yep, your sensor is bad or your wiring is screwed up. Check the wiring. If that's bad fix it and check the readings. Becareful to use the same gauge/type/length of wire when repairing. Some types of temperature sensors are sensitive to this. If the wiring is good, buy a new sensor.
