Old 11-12-2012, 03:42 AM   #1
Davo_330ci
My Ride: 2002 bmw 330ci
cold start problem
hi i have a 2002 bmw 330ci every time in the morning when i first start my car there is a settings light that turns on next to where it says if your in park or drive then when i try to put it in gear the service engine light comes on when it gets to normal temp i turn it off and back on the setting light goes away but the service light stays on intel later on in the day then that turns off can any one tell me what the problem is and how it can be fixed
Davo_330ci is offline   Reply With Quote
Old 11-12-2012, 04:54 AM   #2
Shonky
My Ride: 2004 E46 M3
Firstly, the full stop key is in the bottom right of the keyboard, usually the second key to the left of the right shift key.
What does the "settings" light look like? Take a photo or find a dash picture.
Get the codes read.
Shonky is offline   Reply With Quote
Old 11-12-2012, 05:32 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you read the first link below in my signature regarding the CEL light.
Likely the SAP vacuum hose that runs around the valve cover?
But you likely have many other rotted vacuum hoses as well given the age of the car.
Old 11-12-2012, 10:32 AM   #4
Davo_330ci
the light looks like that next to the p
Old 11-12-2012, 11:34 AM   #5
jasonbimmer
My Ride: 2001 BMW 330xi
ugh oh. the cog of death. transmission issue.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
