Old 11-12-2012, 09:13 AM   #1
e46fanatic92
My Ride: 330
Help
Hi guys this is my first post on this site but Ive always been a fan. I need some help with my 330ci. I had a pioneer head unit in my car that had died. So I purchased a factory hk unit. But when I had tried to replace the unit, I was unable to do so. The idiot who previously owned the car had removed and cut the factory harness to pieces. But I gave up so I taped up the cables individually and left it be, so I could order a new harness. But when I started my car, It had died. I lost all power in the car, and it did not start. I have no power at all in the car. I have no light windows etc. Please help. Thanks.
e46fanatic92 is offline   Reply With Quote
Old 11-12-2012, 09:21 AM   #2
s14realm3
My Ride: 03 ZHP, 95 M3, 91 M3
Your constant power wire is shorted and draining the battery, go back in harness and seperate each wire and tape off the ends so they won't touch each other. Recharge your battery hopefully it will hold a charge and start the engine.
s14realm3 is offline   Reply With Quote
Old 11-12-2012, 09:22 AM   #3
dusty132
My Ride: 2002 330ci
did you check your fuses?
dusty132 is offline   Reply With Quote
Old 11-12-2012, 09:30 AM   #4
e46fanatic92
My Ride: 330
Thanks for all the responses so quickly. s14realm3 is there any chance of fire? I didn't have any time to check. I just tried to start it today and it died. I had class so I had left it alone.
Old 11-12-2012, 12:38 PM   #5
PsychoCemia
My Ride: '05 330Ci ZHP
If there are power wires shorted, then yes, there is a chance of fire. It's small, though, because those wires are on 5 or 10amp breakers, which will usually pop of there is a short like this.
......Sparkling Graphite '05 330Ci ZHP w/ NAV......
PsychoCemia is offline   Reply With Quote
