General Off-Topic
Old 11-12-2012, 11:09 AM   #1
makecopies
My Ride: Gods Chariot
Question A Toyota/Lexus 1UZ-FE electrical ? maybe...
Bought a 1995 Lexus LS400. Drove the car to work. Leaving work that evening and all the lights got dim. So I drove straight to Advance. They tested it and said the battery is totally dead. So I bought a new battery. Car fires right up. Drove the car home. Next morning driving the car to work all the lights get dim again. So I figured it must be the alternator. Dropped the car off to get the alternator replaced. Since the power steering is located above the alternator and looking at the service records the power steering pump replacement was the last service it had. I suspected the the pump leaked fluid into the alternator.
Fast forward to today..mechanic installed the alternator. When you turn the key to start it up the battery light doesn't show up on the indicator lights. The car now will not start. All the fuses inside and outside under the hood are good.
He wants to get the wiring diagram from Lexus and go to town
Any thoughts?
Any knowledgeable Toyota folks?
Yeah I know its a BMW forum
makecopies is offline   Reply With Quote
Old 11-12-2012, 04:10 PM   #2
xtacy12
My Ride: its stock
open ur wallet .. pull out the plastic ... spread ur cheeks.
CSL 1-Piece Lip | Blackout Kit | Apex EC-7 | 75mm Studs | Moteki SR48 Gold Lugs | Yellow Stoptech ST40 | KW V2 | Vorshlag Camber Plates and RSM | UUC Adjustable Rear Control Arms | RRT Reinforced Rear Subframe | AFE Super Stock Intake | JVT Headers | SGT X-Pipe | 6.5lb Titanium Muffler | FS Tune by Frank Smith
xtacy12 is offline   Reply With Quote
Old 11-12-2012, 04:25 PM   #3
SamDoe1
My Ride: 4cyl of fury
I thought Toyotas never break?
Old 11-12-2012, 04:38 PM   #4
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Make sure the alternator was installed correctly first. Ensure the new alternator functions properly out of the car - you can get it tested. Check the current draw with the car off, and trace that by pulling fuses
Chris
dreamdrivedrift is offline   Reply With Quote
Old 11-12-2012, 04:38 PM   #5
v8 5
My Ride: 6 speed BMW
it's the 2jz bro
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline   Reply With Quote
Old 11-12-2012, 04:42 PM   #6
DILLA
My Ride: 330i ZHP/VW Jetta
Good ole 1uz-fe, I sold my sc400 with 275,000 on it, I had similar problems, replaced the battery and alternator, and didn't have any problems after that. did the car run after the mechanic installed the new alternator?
LRx
DILLA is offline   Reply With Quote
Old 11-12-2012, 08:37 PM   #7
makecopies
Car starts up but still has dim lights like the battery is dying.
so frustrating.
Can a brand new alternator be bad?
Old 11-12-2012, 09:01 PM   #8
dreamdrivedrift
so frustrating.
anything can happen. Could be a wire that was damaged when the alternator was installed as well.
Chris
Old 11-13-2012, 03:45 AM   #9
bishop1977
My Ride: 04 330i ZHP S/C
Battery cable could be bad ha same issue on 2000 ls
bishop1977 is offline   Reply With Quote
Old 11-13-2012, 12:25 PM   #10
Starfire Auto
Past Site Sponsor
My Ride: W/E I have in stock
youre damn right a "brand new" alternator can be bad. Ive had many alternators and starters be bad right out of the box. It was probably a reman, and not brand brand new. Did you pay $150 or $300 for it?
Starfire Auto is offline   Reply With Quote
Old 11-13-2012, 02:36 PM   #11
makecopies
150.00 and yeah it is reman.
Old 11-13-2012, 02:54 PM   #12
Starfire Auto
Past Site Sponsor
back it goes to the shop sir! It was probably dead out of the box
Old 11-13-2012, 03:50 PM   #13
iDriftYou
My Ride: is a HighWay monster
Check the 100 amp ALT fuse, I blew one in my supra because my idiotic friend plugged the battery in wrong.
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 11-13-2012, 03:57 PM   #14
v8 5
you don't even have a 2jz
Old 11-13-2012, 04:16 PM   #15
M3Inline6
aka...Dark Snow
My Ride: '17 Nardo Grey M4
Originally Posted by xtacy12 View Post
open ur wallet .. pull out the plastic ... spread ur cheeks...
..."here comes the iron sheik. If you gon' lick on my sugar cane, please don't use yo' teeth!"
Originally Posted by Qwel on "Manhattan Project"
You heard of me.....burgandy and outlines like murder scenes; Germany..took ferns and flat whites for blurring greens.
M3Inline6 is offline   Reply With Quote
Old 11-13-2012, 10:02 PM   #16
iDriftYou
I have the motor which helped design the 2jz.
-Shehroz
Future: GT35r
My DIY:
Old 11-13-2012, 10:44 PM   #17
v8 5
do you even have a 2jz
Old 11-13-2012, 11:23 PM   #18
iDriftYou
No bro, no.
-Shehroz
Future: GT35r
My DIY:
Old 11-13-2012, 11:55 PM   #19
v8 5
No bro, no.
that's not even a 2jz, you should swap in a 2jz
Old 11-14-2012, 12:02 AM   #20
Bart Taylor
My Ride: 2000 323i touring
shi t isn't funny...never was....STF U
and OP, get it running and buy ITBs
Your car, along with every other "stanced" monstrosity, looks like a steaming pile of sh1t.
Originally Posted by mistrzmiasta View Post
i know in your head that sounded like a nice comeback/argument but you just sound like a fool.
Bart Taylor is offline   Reply With Quote
