#61 |
Lol, he reply a second fast
#62 |
Ok, will do and get back with you guys tomorrow. Thanks again
#63 |
![]() Last edited by drbworld; 01-28-2013 at 08:26 PM. |
#64 | ||
im thinking the other end of the circuit, between the battery and frame. Quote:
#65 |
this i would not do. putting direct battery voltage to the switched side of the solenoid is a bad idea.
#66 | |
Old school mechanics use to do this for testing. Just because you don't know about it doesn't mean it's a bad idea. And looking at your other post, you just quoted icoleman who suggested the same as I did, and said try that too
![]() Last edited by drbworld; 01-28-2013 at 08:40 PM. |
#67 |
i thought you meant put b+ straight to the starter motor.
#68 |
I didn't suggest directly connecting the battery to the small terminal (only the large, to bypass the main power cable), but I see no reason not to. I would just test for V at the terminal while attempting to crank, though.
#69 |
That's exactly what I'm saying. You can jump either from the positive wire like in the picture I posted or directly from the battery terminal. Which, for our cars would be the terminal near the passenger well. This way by passes the relay and is only used temp for testing purposes.
#70 |
Maxwell, icoleman, and drb world, back up in the thread a little and see where I have done this but the voltage still dropped to zero. I'll try to post a video tomorrow after work. Thanks
#71 |
I saw a couple of pictures where you testing volt, but I didn't see where you put a jumper wire directly as I described?
The reason I suggested this is to bypass any short circuit somewhere if that was a problem. Directly from the battery terminal will rule out your starter and if it cranks over.
![]() Last edited by drbworld; 01-28-2013 at 09:34 PM. |
#72 | |
#73 | |
#74 | |
And you are 100% correct, jumper to the ignition switch is done all the time. No problem. |
#75 |
#76 |
I had the battery tested but I went ahead and exchanged for a new- didn't cost so why wouldn't I. Anyhow this is exactly the order of today and the results:
-I put new battery in, secured the terminals. I put my original starter back on(had it tested at autozone a couple of times last night). Connected all my starter terminals. -I then used a pair of jumper cable(negative only) to jump from my B- terminal in the passenger storage well. I press the clutch, turn the key and the starter solenoid shoot the bendix out but it does not turn. It clicks once, all of my lights dim and it does not want to roll over. -I then turn the crank with a wrench to see how it feel. It feels nice and smooth with good compression. Make about two rotations. Then I try to crank again with the key and it turns over an attempts to crank. Could've probably been stronger but it sounded good. Positive if everything were together it would have cranked. Just a little description, but the voltage was still dropping with that setup. I will attempt to post a short video after work tues. |
#77 | |
To be clear, it would be OK to jumper the ignition terminal on the starter motor from the hot lead on the starter itself, OR from a long jumper all the way from the positive battery terminal. Doesn't matter where you pull in the voltage from as long as the source is the car's storage battery. |
#78 |
We all learn something new everyday. I certainly do, especially on this forum. I try not to bash people, instead, I'm open minded to see if there's something I'm not sure about or new to learn.
#79 | |
I want you around when mine eventually needs replacement. I'll take you exactly at your word here as how you have described things in your car. What you describe sounds like you definitely have a high resistance connection somewhere from your battery to your starter terminal. I've already walked you through checking all the connections along the way from the battery. Someone else also gave tips as to how to check for this. If you had a thick jumper cable long enough to reach from the battery positive terminal all the way to the large starter terminal, you could jumper this to verify the above conclusion. Careful not to brush against ground! When you measure the voltage, exactly where do you get your ground? You should be measuring to the engine block ground, not the chassis ground. This puts the engine block ground strap into the test. I've requested other tests along the way and not gotten answers to all. I can only work with what you find in these tests. |
#80 |
Ha, you guys are killing me. And yeah, I've got it down to a science...swivel extension after the socket, two six inch extensions, swivel and another six inch extension to the wrench. Go in over the transmission and once it's free drop it straight down. The most time consuming is removing the skid/frame plate underneath.
- I think the problem has hot to be my B+ terminal. Going to clean it really well and re fasten. Probably didn't clean and get tight enough when I did the engine swap. Must've worked lose and got a little rusty and dirty over about a year |
| Tags |
| alternator wiring, electical, no crank, no start |
