///M3 Forum
Old 09-29-2006, 12:05 PM   #1
scottn2retro
My Ride: 2001 S54 M Roadster
Solution to the infamous SMG 'slurring of the gears' problem?
Hi All -
We are now (we did not have it in the first part of the season) having the famous SMG 'slurring' of the gears anomaly on 3-4 upshifts.
Has anyone ever found a definite solution the problem?
02 M3 SMG - Prepared Class BMW Club Racer
www.TotalMotorOils.us
www.NittoTire.com
Photo Gallery
scottn2retro is offline   Reply With Quote
Old 09-29-2006, 06:19 PM   #2
SnowsM3
My Ride: 2004 M3 SMG
What do you mean "slurring" of the gears? If you mean that the upshift isn't quick & crisp then I had that problem about a year ago on the 2-3 upshift. I used to be able to chirp the tires in the 1-2 & the 2-3 gear change with DSC off and the transmission in S6. All of a sudden the 2-3 gear change was kinda lazy and the revs would go up like the clutch was slipping. Took it to the dealer and of course they couldn't find anything wrong.
Here is how I corrected it. I did the double-paddle hold trick that is described in the owners manual. I also reset the tire monitor. I had to do this a couple times each and I can't remember the order I did them in but everntually the problem went away and I was once again getting crisp & quick 2-3 upshifts in S6. The problem hasn't happened again in over 20k miles. Hope this helps. Good luck!!
SnowsM3 is offline   Reply With Quote
Old 09-29-2006, 07:25 PM   #3
scottn2retro
Thanks - I think our tire monitor light is on, so I'll try that.
www.NittoTire.com
Photo Gallery
Old 11-13-2012, 09:13 AM   #4
tienne85
My Ride: e46 m3 smg
I bought a smg without a manual. So how do i reset the tire monitor and how do i check my fluid or were do i check it.
tienne85 is offline   Reply With Quote
Old 11-13-2012, 12:02 PM   #5
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Tire monitor reset procedure:
ABOVE 40 mph (I do mine @ 50mph) put the car into neutral (0 in your case) and hold down both paddle shifters for approx 4 seconds. Once complete, make sure your foot is not on the throttle and move the selector back to the drive position (move selector to the right). That is it.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-14-2012, 05:13 AM   #6
roadtrip1098
My Ride: 04 M3 SMG LSB
The 3-4 shifts can also be caused by the compression springs in the tranny which are pretty cheap. It wouldn't hurt to get the codes read by the DIS system and see what errors are there. Not everything causes a COG light. Another thing to consider are sychros (depending on mileage and how hard you drive the car).
roadtrip1098 is offline   Reply With Quote
Old 11-14-2012, 07:04 AM   #7
Shonky
My Ride: 2004 E46 M3
That is the SMG reset procedure, not the tire monitor one. I've never really figured out the tire monitor one to be honest but there are manuals here:
http://www.bmwsections.com/docs/m/
Shonky is offline   Reply With Quote
Old 11-14-2012, 10:01 AM   #8
scca_ziptie
Ha, sorry just realized I replied completely wrong.
Tire reset procedure: start the car, before putting the car into gear press and hold the tire monitor button (on panel with sport button) for approx 5 seconds, put the car in gear and drive away. Once the reset is done the TPMS light on the dash will turn off and you're set.
Old 11-15-2012, 02:00 PM   #9
DonovanM3
My Ride: e46/bike/Airplane?
Hey guys, I had the slippage and nasty feeling in the SMG system, I did a hard reset and everything was great after that
Unplug negative terminal of battery and let sit for 5 hrs
04 Jet Black SMG - NAV
Cinnamon
Sonic Tuning Spacers 15mm \\// More to come...:shifty:
Valentine V1
BMC filter
Full real carbon trim to include seat backs and paddles
Scorza
Euro Header+Cat
!*!!* All EURO parts : m3e46freak@yahoo.com !!**!*!
DonovanM3 is offline   Reply With Quote
