Old 11-12-2012, 04:09 PM   #1
ajesse
My Ride: 2002 m3
help!! whats wrong with my car!!
ajesse is offline   Reply With Quote
Old 11-12-2012, 04:12 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
Actually you get the picard double facepalm
Old 11-12-2012, 04:12 PM   #3
ajesse
My Ride: 2002 m3
sorry having a hard time uploading a video
Old 11-12-2012, 04:14 PM   #4
NOVAbimmer
My Ride: E60M
you need IT help before we can give you car help
NOVAbimmer is offline   Reply With Quote
Old 11-12-2012, 04:20 PM   #5
ajesse
My Ride: 2002 m3
there finally got it up sorry guys
Old 11-12-2012, 04:25 PM   #6
lcoleman
My Ride: '79 Massey Ferguson
Old 11-12-2012, 04:27 PM   #7
ajesse
My Ride: 2002 m3
battery isnt dead i just had it charged and checked to make sure it was good. after putting it back in it started doing that then the battery died within about 15-20 minutes
Old 11-12-2012, 04:28 PM   #8
Albers
My Ride: 330ci
Alternator
Albers is offline   Reply With Quote
Old 11-12-2012, 04:31 PM   #9
ajesse
My Ride: 2002 m3
well let me start my telling you that it started when i was driving home it suddenly died on me at a stop light, initially i thought the fuel pump so i went to check it but i realized my battery was dead and i thought it was from leaving the interior lights on all night so thats when i took it into autozone had them recharge it then test it everything was good went to put it back thats when i had this problem.
Old 11-12-2012, 04:54 PM   #10
NOVAbimmer
My Ride: E60M
is this a common phrase for you?
Old 11-12-2012, 04:56 PM   #11
ajesse
My Ride: 2002 m3
NOVAbimmer your really hilarious. im just trying to get some help with my car you dont to stick around and give me ****. you can help or leave simple as that.
Old 11-12-2012, 04:57 PM   #12
BimmersGarage
My Ride: E46 330i
@ajesse,
It's very likely your battery. The E46s are very sensitive to weak batteries.
Furthermore, if the battery is original or more than 3-5 years old then it's Definitely time to have it replaced.
BimmersGarage is offline   Reply With Quote
Old 11-12-2012, 05:00 PM   #13
ajesse
My Ride: 2002 m3
@bimmergarage thanks for the advise. im not too sure if it is the original. would that cause the car to suddenly shut off randomly and not want to start? ive never had any problems before
Old 11-12-2012, 05:07 PM   #14
WDE46
If the car is already running, it should continue running with a dead battery, though maybe BMWs really hate dead cells. Usually a dead cell can run if you jump it, but it will cause weird electrical phenomina. Though, like I said, maybe BMWs just don't let themselves run with a dead cell. I'd replace the battery if it's old anyway. If the battery is new and gives you strong voltage readings when you test it, then you need a new alternator. Battery cells die very suddenly though, so if I were you, I'd hope for a dead battery.
Old 11-12-2012, 05:11 PM   #15
BimmersGarage
My Ride: E46 330i
I know it may seem odd that "weak/old" battery could do this (or have this effect to our E46 BMWs) but it does. The cluster lights comes on like normal but it just doesn't crank... (or you may get weird light effects on the cluster, etc.)
BMWs are special...
If you want to confirm > just go to autozone and ask for a brand new 49-DL battery*, drop it in your vehicle. I bet you two cases of beer that it'll crank right up like normal.
*or something with a minimum of 750CCA
That could very likely be the age of the car.. ie: combination of an OLD alternator and battery. If you had your A/C, radio, headlights AND along with all the other onboard electronics) ALL running - the load on the OLD alternator just couldn't keep up & still charge a horridly old battery.
Old 11-12-2012, 05:15 PM   #16
Scooby24
My Ride: '03 330i ZHP Sedan
Yup, sounds to me like his alternator is dead.
Scooby24 is offline   Reply With Quote
Old 11-12-2012, 05:20 PM   #17
THECLEANERBEAMER
My Ride: 2002 325i
i believe its the alternator. when it first died driving home you could start it again right? if so its probably the alternator. just go to o'reilys or somewhere and get your battery test just in case
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 11-12-2012, 05:23 PM   #18
ajesse
My Ride: 2002 m3
When it first happened it didn't start again till the next day and I took my battery to auto zone and had it recharged they also said it was still good
Old 11-12-2012, 05:27 PM   #19
BimmersGarage
My Ride: E46 330i
It's still good to their little voltage meter.. Not for your M3.
Use the hidden OBC codes to see actual voltage. However, since you can't get the engine to start it won't help in this instance. (note: you should get 14.1 volts during idle)
The quickest solution is to drop a fresh battery in and see if it cranks, otherwise you'll be wasting time (and perhaps $$$ for a mechanic to) disassembling your alternator for nothing. At least this way you can eliminate the battery to be the cause.
Old 11-12-2012, 05:29 PM   #20
330iPilot
My Ride: Titanium Silver 330i
They don't have the worlds best diagnostic equipment. I've had some bad calls from those guys saying my battery or alternator is good when it was actually bad. The good news is that there isn't anything special about the BMW battery or alternator that I'm aware of so any reputable shop should be mable to take a look at it for you.
330iPilot is offline   Reply With Quote
