Old 11-12-2012, 05:49 PM   #1
nzhorsey
My Ride: 318i e46
Strange Noise on Starting Car...
Hey guys
I have been been having some issues recently on starting the car. 50% of the time it kicks over beautifully, but every other time i turn the key and nothing happens just a whirring sound and then when turn the key back it'll get an ugly kick as it sound like something has not engaged properly. Then the second time itll start fine.
You guys have any suggestions? Starter, Solenoid or Key???
Thanks Fellas
nzhorsey is offline   Reply With Quote
Old 11-12-2012, 06:59 PM   #2
silvrXI
My Ride: E46(x2)&E36/7M&YZFR6
That sound is the starter motor spinning but not engaging with the flywheel. Likely due to a weak solenoid or mis-alignment of starter gear (missing dowel pin or loose bolt). Inspect starter, if it appears to be mounted securely against bell housing, then replace it. If it is loose, remove it, inspect dowel pin, and re-install. Ensure all connections are clean and tight.
silvrXI is offline   Reply With Quote
problems, start, starter
