Old 11-12-2012, 07:12 PM   #1
Nerdy46
My Ride: 328i
New e46 Owner: Airbag light wont clear, Hesitation Under 2k RPM
Hello,
Just bought an e46 and have some questions.
First some info about the car:
1999 e46 328i 193k miles
The air bag light is on and i cant get it to clear, I have a R5/SRS and ive plugged it in to the 20pin connector under the hood. It reads codes just fine.
It shows the following codes:
Table 02
Codes: 01,18,03
Ive tried to clear them with no luck. Ive even created new codes on purpose by disconnecting the entire pass seat harness... That gave me new codes 11 and 6. After reconnecting i tried to clear again with no luck.
Ive also removed the center console and checked the connection on the SRS module, removed it, reconnected it. No go.
Any ideas?
I assume 01 is from when the previous owner had the door off for a repair. 03 because the battery was at a low voltage and 18 because of the occupancy mat.
I performed the bypass on the mat thinking it may be preventing me from clearing all the codes? No luck...
The hesitation problem is under load from 1.2k-2k RPMS in any gear while under load.
So far ive replaced the following:
Plugs
lower intake boot
Vac line to the valve cover from oil thingy
Vac line to the SAS that was cracked
Air filter (also cleaned the maf and looked at the TB)
Any ideas on that one???
Nerdy46 is offline   Reply With Quote
Old 11-12-2012, 11:13 PM   #2
Nerdy46
My Ride: 328i
Any ideas??? I have alot of parts on the way for PM. If there is something im missing let me know....
Really need the airbags straitened out for inspection.
Old 11-13-2012, 12:20 AM   #3
haurelio
My Ride: 2001 bmw 325i
it might be the belt tensioner.. try removing the yellow clip under the seat for a few minutes. clear codes again..report back
Contact me if you need to unlock your phone.
Also can code your car
Old 11-13-2012, 12:44 AM   #4
Nerdy46
My Ride: 328i
Already disconnected and reconnected seat wiring
Old 11-13-2012, 02:43 AM   #5
Megalocnus
My Ride: 05 330i ZHP/MT
I didn't understand, were you able to clear the 02 11 code?
Megalocnus is offline   Reply With Quote
Old 11-13-2012, 03:01 AM   #6
honeybee
Banned User
after all these you try, this problem still do not solved?
honeybee is offline   Reply With Quote
Old 11-13-2012, 03:22 AM   #7
jcjdavis1
My Ride: 323ise 1999 saloon
Hi. I don't see you mentioning that you checked the Airbag fuse. Jim
The older I get the wrong bit gets stiff!!
jcjdavis1 is offline   Reply With Quote
Old 11-13-2012, 03:34 AM   #8
FastCHAZ
My Ride: 02 325ci
bro have you ever simply checked for a blown fuse? my airbag light was on for 1 year
before I changed mine.
FastCHAZ is offline   Reply With Quote
Old 11-13-2012, 08:58 AM   #9
Nerdy46
My Ride: 328i
I have visually inspected fuse 11 but have not put a multi meter to it. Are there any other fuses that are associated with the Srs system?
Old 11-13-2012, 05:53 PM   #10
Nerdy46
My Ride: 328i
Any more ideas?
Old 11-13-2012, 06:23 PM   #11
Nerdy46
My Ride: 328i
Just checked all fuses with a multimeter and they were all good.
Old 11-13-2012, 10:23 PM   #12
silvrXI
My Ride: E46(x2)&E36/7M&YZFR6
FOR YOUR HESITATION: replace "suckimg jet pump" for vacuum control,( not the one in the gas tank) replace vanos seals, clear adaptations...
silvrXI is offline   Reply With Quote
Old 11-13-2012, 11:16 PM   #13
Nerdy46
My Ride: 328i
I already plan on replacing the disa oring and checking the valve. I guess vanos seals will be next.
Old 11-13-2012, 11:59 PM   #14
Barneyhyphen
My Ride: 2004 M3 Convertible
Check the VANOS solenoid(s) as well, for correct operation.
BH
Barneyhyphen is offline   Reply With Quote
Old 11-15-2012, 01:16 AM   #15
Nerdy46
My Ride: 328i
Thoughts on srs issue?
Old 11-15-2012, 01:18 AM   #16
Nerdy46
My Ride: 328i
Is there anyway to bench test the module???
Old 11-15-2012, 11:47 PM   #17
Nerdy46
My Ride: 328i
ttt
Any ideas on testing my module?
Old 11-18-2012, 11:58 AM   #18
Nerdy46
My Ride: 328i
Old 11-18-2012, 12:13 PM   #19
dknightd
My Ride: 2002 330 cic
If you can't sort it out yourself, or through search, you might need to hire a professional.
dknightd is offline   Reply With Quote
Old 11-18-2012, 12:27 PM   #20
Nerdy46
My Ride: 328i
I fully capable i would just like to know if anyone had a diagram or anything to bench test my module. It sounds like the module is done for. I have a new one on the way.
I just figured there may be someone on here more knowledgeable then me when it comes to electronics trouble shooting
