Old 12-01-2012, 01:30 PM   #1
S-Works
My Ride: 02 330ci
New to me 02 330ci, clock reads zero's
Just bought this car yesterday (first BMW) , can't set the clock. It reads zero's. I've read through some posts, but have not found anything specific.
The button for setting the clock works when you push it in to change outside temp between C and F. But in the clock display, it does nothing. When rotated either way or pushed.
My thinking so far is the switch is bad for rotating, but not pushing. Anything else? Is there a repair for the switch??
TIA
S-Works is offline   Reply With Quote
Old 12-01-2012, 01:49 PM   #2
tks
My Ride: slower than yours
On the turn signal lever thing, you can push that thing in to get different readings: mpg, mph, temp, clock.
Set that to clock and try again.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 12-01-2012, 02:06 PM   #3
S-Works
My Ride: 02 330ci
Thanks for your response, but I'm referring to the clock set button not working to set the time when it's in the proper mode.
Old 12-01-2012, 02:36 PM   #4
WDE46
My Ride: '13 128i, '04 330Ci
Unplug the negative terminal of your battery for a while...maybe that'll reset something.
Old 12-01-2012, 02:45 PM   #5
NE1L
My Ride: 320Cd M-Sport
I think you need to have the stereo set to display the clock as well as the cluster before you can set the time. Then you can change the stereo display back to what you want.
NE1L is offline   Reply With Quote
Old 12-01-2012, 03:00 PM   #6
MercForHire
My Ride: M235i 6MT
There are bigger problems to worry about than this useless clock.
Check and replace cooling system
Old 12-01-2012, 03:03 PM   #7
tcphoto
My Ride: E92 335 MT Coupe
Start reading the owners manual, it's available online if you don't have one and it contains a wealth of information.
tcphoto is offline   Reply With Quote
Old 12-01-2012, 03:18 PM   #8
tks
HAHA.
OP, I re-read your original post and I noticed I misread it! Maybe get a new turn thingy?
OR always leave your radio on, and never push it in clock position so problem dissapears =P
Old 12-01-2012, 03:29 PM   #9
scarede46er
My Ride: 2001 BMW 325i ZSP
Rotate the other knob. That will set the clock. Hold the torque to make the time change faster.
Old 12-01-2012, 03:38 PM   #10
S-Works
My Ride: 02 330ci
HaHaHa, you guys are bit more livier than the Saabnet crew. I like it!
I've read the manual, that's how I learned how to set the clock. I've had both displays set to clock. Nothing.
It has 125K on the clock, I have PO invoices for water pump at 95K, but I don't know what kind of Pump. I was going to change it to zero things out, along with the oil, tranny, etc. What water pump is the pump to get for this car? Coolant? Auto tranny fluid of choice too.
TIA
PS: the switch I think is bad is the one on the instrument cluster, not the turn signal stalk.
Old 12-01-2012, 04:05 PM   #11
WDE46
TIA
HOLY **** GENIUS
