Old 08-12-2013, 04:11 PM   #1
BMARTINW
My Ride: E46 S54 SALOON
S54 swap, were could i get the EWS deleted off my DME, help?
Like the title says, doesn anyone know we're I could get the EWS deleted of my ECU/DME? I'm in Cali.
BMARTINW is offline   Reply With Quote
Old 08-12-2013, 07:39 PM   #2
TerraPhantm
My Ride: M3 & ZHP
Do you want to eliminate it completely? Would virginizing it be sufficient? Virginizing it would allow it to pair with your existing EWS
Old 08-12-2013, 08:51 PM   #3
JohnBlaze
My Ride: Black Sunshine
If there's no one local you can trust, you can use these guys. I know two people who found success using them to align everything and I'm one of them.
http://www.rpmmotorsport.net/
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 08-12-2013, 09:49 PM   #4
BMARTINW
I'm doing a s54 swap on my 01 sedan, I think it need to be deleted because from what I've read my 330 EWS won't work with a s54 DME, what I need is to get the EWS deleted, and most people say to get the DSC deleted too but I want to put the whole brake system from an M3 I know it would be a PITA but I'm more than half ways done so might as well finish it.i looked in to RPM but they are expensive, I've seen a couple of plp around but johnblaze has a point.
Old 08-12-2013, 09:52 PM   #5
HakenTT
My Ride: 323i with S54
I would say I am the most qualified to tune your ECU for your swap. Here is my S54 swap thread:
http://forum.e46fanatics.com/showthread.php?t=977520
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 08-13-2013, 12:04 AM   #6
TerraPhantm
My Ride: M3 & ZHP
The EWS modules are all the same; as long as the M3 DME is virginized, it'll willingly pair with the EWS. I can also delete it, but unless you plan on swapping DMEs frequently, I think it's better to retain the EWS (for whatever security it adds). M3 DME would have also played fine with the 330 DSC.
Old 08-13-2013, 08:43 AM   #7
JohnBlaze
I think that depends on the pieces you're coupling, for instance if you had a 01 330i to start with, and a 05 M3 you were using to morph there are some variances there when comparing to a 01 M3.
Good luck OP which ever path you travel. If you're not to far from Khalid I think his name is, you should holler at holler at him.
Old 08-13-2013, 01:51 PM   #8
TerraPhantm
My Ride: M3 & ZHP
An 01 330's DSC is actually closer to an 05 M3's than an 01 M3s. 01+ E46 non-Ms and 03+ M3s have the DSC MK60 module. 01 and 02 M3s have the DSC MK20. EWS module didn't change throughout the run, so that's not a problem
But either way it doesn't matter. The DMEs are all essentially the same (technically there was a change in 2004, but they're backwards and forward compatible -- BMW actually sells you the newer variant even if you're ordering for an 01 M3)
Old 08-13-2013, 02:21 PM   #9
JohnBlaze
ok.
