could an aftermarket intake cause EML light and car dying? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 11-13-2012, 10:58 PM   #1
lsb01
My Ride: e46
I put in aftermarket intake and seems EML light goes on and then my car dies after I press accelerator from time to time.
lsb01 is offline   Reply With Quote
Old 11-13-2012, 11:24 PM   #2
zabalzae
My Ride: 01 330ci
Once my friend put a aftermarket intake on his Toyota celica n cause all kinds of weird shhtt
zabalzae is offline   Reply With Quote
Old 11-14-2012, 08:38 AM   #3
lsb01
My Ride: e46
noone else?
Old 11-14-2012, 10:09 AM   #4
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Are you sure that the new intake is fitted securely? I ask because a vacuum leak could cause the car to die and more than likely it could cause and EML. Is that the only modification that you have done since the EML has been illuminating?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-14-2012, 03:46 PM   #5
mpower95
My Ride: E46 M
If you damaged the MAF when installing the intake and filter, this could have caused the issues. Get someone to pull the codes for you, will make things a lot easier for you.
mpower95 is offline   Reply With Quote
Old 11-14-2012, 04:00 PM   #6
scca_ziptie
+1 on the code reading and damaged MAF possibility. That will make it a helluva lot easier on yourself and the ones trying to help with the issue.
Old 11-14-2012, 04:12 PM   #7
cold m3
My Ride: E46 ///M3
stick with the oem intake... and yes it could to answer your question especially the cone k&n ones
Photos of My ///M3
cold m3 is offline   Reply With Quote
Old 11-14-2012, 06:18 PM   #8
lucky_doggg7
My Ride: 2005 M3
About aftermarket intakes, which are most of them with the exception of ECIS system and perhaps one or two others, they all do not have a provision to incorporate something known as the "MAF Screen", which is on the stock Intake system. This screen prevents turbulent or tumbling air coming across the sensor, from what I understand. It has been well documented that M3s that do not have this screen installed will on occasion upon engine deceleration, an idle stumble will occur, then the injection system may correct the stumble in time, but if not, the engine shuts-off. In my readings, some M3s were affected by being screen free but others reported this idle stumble upon deceleration, so it seems to be a hit or miss matter.
Just Google "MAF Screen" and you will see plenty of old posts on the matter. Try carefully removing the screen from your stock intake and incorporate it into whatever intake is on your M3 now. This screen, is not available for separate purchase from the dealer; it is part of the whole induction system, located ahead/up stream of the MAF. This is the first step to diagnosing your engine shut-off issue.
