Engine ran overheated, lost alot of oil and now no compression - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-13-2012, 10:40 PM   #21
Nerdy46
My Ride: 328i
Junkyard engine.
Nerdy46 is offline   Reply With Quote
Old 11-13-2012, 10:52 PM   #22
Barneyhyphen
My Ride: 2004 M3 Convertible
Dang, the boat anchor pansies are out in force! No nads.
Tear the head off and take a gander (look).
If the block is flat and you decide to go the HG route, DEFINITELY take an extra 2-3 hours and do the 24.5mm Time Serts.
Just did the same job on my daughter's 2000 323i.
Take the head to a good machine shop and see what needs to be skimmed. IMHO, if more than 13-14 thou, go replacement head or replacement engine.
Replace all exhaust guides and recut/grind the valves. If up to 6/7 thou to come off the head, use regular 0.7mm HG, if 8-14 then used oversized 1.0mm (12 thou fatter) HG.
All new gaskets, all new vacuum pipes. DO THE VANOS seals.
Good luck.
BH
Barneyhyphen is offline   Reply With Quote
Old 11-14-2012, 05:55 AM   #23
pawelgawel
My Ride: 330CI
Save yourself the headache!
replace the engine... agham s54 agham...
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 11-14-2012, 07:26 AM   #24
Valkyn
My Ride: 2000 328i
The engine from what years and models would be a direct swap into a 2000 328i?
Valkyn is offline   Reply With Quote
Old 11-14-2012, 11:33 AM   #25
pawelgawel
My Ride: 330CI
s54 is an M3 engine.. any e46 engine will fit, but s54 will require more items for proper operation.
Id use m54 from a 330 with low miles.
Old 11-14-2012, 11:39 AM   #26
Brinkley
My Ride: 99 328i, 07 z4 3.0
I would attempt to source a 328 motor. 99 & 2000. car-part.com is a good source. Failing that, I think Z3s also had m52tus, depending on the year. Remember your car should be drive by cable not wire, one thing to consider if you want to get a newer motor such as from a 330.
Brinkley is offline   Reply With Quote
Old 11-14-2012, 11:56 AM   #27
WDE46
My Ride: '13 128i, '04 330Ci
He can reuse the M52 throttle body on the M54. Flashtwosix has a whole thread on putting a M54 3 liter in a 323i.
Old 11-14-2012, 11:59 AM   #28
Brinkley
Indeed. Just pointing out that there are some differences between the motors to him.
Old 11-14-2012, 12:44 PM   #29
trizzuth
My Ride: 234k, 16yr old B3AST
it just blows my mind in this day and age that people are stupid enough to keep driving after something like this happens. My sister did it about a year ago, she's a F**n idiot too.
2001 BMW 330i - Current at 235K
1996 Mitsubishi Galant S - gone at 121K
1993 Volvo 850 GLT - gone at 89K
1987 BMW 325 - gone at 238K
trizzuth is offline   Reply With Quote
Old 11-14-2012, 10:33 PM   #30
Valkyn
My Ride: 2000 328i
Spent a few hours after work the last two days messing with it. Pulled the valve cover off and everything looks okay under there:
Pulled the intake manifold off tonite...all I have to say is those Germans are damn crafty with attaching **** to the bottom of things where its next to impossible to get to. All the PCV lines were super brittle and the PCV itself and two lines broke while removing them so I'll be replacing all that stuff.
And it looks like it has had a coolant leak where this steel line goes into the cylinder head for awhile now
Head comes off tomorrow nite, going to make a tool to take the head bolts out at work.
Old 11-15-2012, 07:14 PM   #31
pawelgawel
My Ride: 330CI
even then.. you won't be able to tell if the head is damaged... you'll need to have it leak checked.. might be warped.
Old 11-16-2012, 04:53 PM   #32
shahbaz99
My Ride: Clean 330ci
why not just do an engine swap? You got the car for dirt cheap so spend some money on putting over the top. Get an M54B30, put some bolt ons software to make it sweet. Or go a little crazy and put an S54 to make it a 332i. No point chasing issues on that toasted motor. Scrap it and start fresh. You can spend $$$ and get it back to being a stock 328i with a haunting past that will always give you issues. Remember that the E46 non-M has an aluminum block which warps real fast when overheated. Or you can spend the same $$$ and build yourself a much faster and better E46 rather than another boring 328.
shahbaz99 is offline   Reply With Quote
Old 11-16-2012, 08:42 PM   #33
Valkyn
My Ride: 2000 328i
Well what do we have here...
Oh shi...got bigger problems.
the 3 and 5 pistons have holes burnt in them. So I have to admit it you all were right I was wrong it's a boat anchor.
So now the question is what new engine should go in it. I like Shahbaz's ideas.
Old 11-16-2012, 08:49 PM   #34
Nerdy46
My Ride: 328i
OUchies.
Old 11-16-2012, 08:58 PM   #35
Sapote
My Ride: E46 2000 323i wagon
check my thread on head replacement; I had overheated ---> cracked head ---> hydraulock engine, but end up DIY (alone) with a used head (ebay) and things are still working fine.
Sapote
Sapote is offline   Reply With Quote
Old 11-16-2012, 09:00 PM   #36
Scooby24
My Ride: '03 330i ZHP Sedan
Well that explains the oil loss. Bummer because pistons look really clean otherwise. Was probably a pretty healthy engine aside from the headgasket and subsequent catastrophic failure.
Scooby24 is offline   Reply With Quote
Old 11-16-2012, 09:07 PM   #37
Valkyn
My Ride: 2000 328i
I tried doing the head bolt torque test and one bolt pulled the threads, only had to try 3 before one pulled it.
What does a rebuild typically cost?
Old 11-16-2012, 09:07 PM   #38
Sapote
whoa! those pistons look so clean!!! are they that way or had been cleaned? It's amazing that the pistons were melted by no valves collision!!! E46 is a great designed engine --- just the engine's top-end and bottom end alone.
Sapote
Old 11-16-2012, 09:34 PM   #39
Valkyn
My Ride: 2000 328i
I didn't clean them, they all look that clean tho.
I still don't understand why I wasnt getting compression on any cylinders when the head gasket looked good everywhere but by number 6 and all the other pistons looked good.
The head isnt obviously warped and looks okay.
Old 11-16-2012, 11:27 PM   #40
Blizare
My Ride: 2001 330xi
No matter how you want to look at this, the cheapest way to go is a 2k used motor. Anything else will be more interesting and cost more, and I always like the idea that now you would have all these spare parts from the blown motor, (depending on what you'd have to swap onto the new one
Blizare is offline   Reply With Quote
