Old 06-11-2006, 02:55 PM   #1
dis
My Ride: 1999 BMW 323i
How to remove intake Manifold on 323i
This my second attempt to remove the intake manifold on my 1999 323i so I can replace the Pressure Regulating valve that resides below manifold. You can see this part from below the car, but there's no way to get to it. I have all the bolts removed from the manifold, but there's still something holding it in place even though I can rock it back and forth. Please tell me what I'm missing. I even had a friend whose quite mechanical and he couldn't see what was keeping the manifold from
dis is offline   Reply With Quote
Old 06-11-2006, 03:55 PM   #2
Paul984
My Ride: 323i
there is a vacuum line that runs to a valve on the back of the manifold. Make sure that the hose for that is off. In addition to that, there might also be clips
holding the hoses that run to the fuel rail.
Paul984 is offline   Reply With Quote
Old 06-11-2006, 04:53 PM   #3
dis
Do you know of any diagrams that clearly show what needs to be disconnected from the intake manifold to free it from the engine. I can't reach any hoses below the manifold, I think it's some kind of bracket that supports the manifold I can't see. With hoses I'd still be able to lift the manifold more then I can.
Old 06-25-2006, 09:43 AM   #4
nEVERCLEAR
My Ride: 323
I got to the same point and couldnt go any further.
Have you removed the intake boot? How do you remove the fuel rail?
I was not able to reinstall 2 or 3 nuts that hold the intake on due to the fuel rail and I think it is causing a vacuum leak.
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 06-25-2006, 03:30 PM   #5
Paul984
My Ride: 323i
there is a bracket underneat the manifold that is bolted to the engine. You should also try having some hold the fuel rail out of the way since you need to lift the fuel rail up a little to get the bracket off the the stud that is on the engine. There are numerous vacuum hoses and wires so carefully pull those off one as you are taking the manifold off.
Old 06-25-2006, 10:23 PM   #6
nEVERCLEAR
My Ride: 323
You have to get at that bracket from behind the crankcase valve. From the lower drivers side of the engine compartment or is there a better location to access it?
Old 06-25-2006, 11:05 PM   #7
nEVERCLEAR
My Ride: 323
http://eastcoasthonda-vw.com/Replaci..._Manifold.html
http://eastcoasthonda-vw.com/Replaci...uel_Lines.html
http://eastcoasthonda-vw.com/Removin...ttle_Body.html
Old 04-19-2011, 12:00 AM   #8
mpostman420
My Ride: 323i 99
needing vaccume diagram or some info on intake manifold
my engine is not getting fire due to the re installation of my intake manifold do you have some pics of the vaccume hoses on the back of the intake it would be quite helpful. and did you experience any thing like that when you put your intake back on??
mpostman420 is offline   Reply With Quote
Old 11-13-2012, 06:16 AM   #9
turnerk2
My Ride: 02 325i
did u ever get that sorted? find the issue?
turnerk2 is offline   Reply With Quote
