Sponsored by BAVSOUND
Old 11-13-2012, 11:33 AM   #1
IrunBimmer
My Ride: 323i
Sun visor tv
A friend of mine got me a set of sun visor tvs for my birthday, they have been sitting around since August. Anyone know how I can go about installing them with out taking them to a shop?
IrunBimmer is offline   Reply With Quote
Old 11-13-2012, 11:39 AM   #2
cposk
My Ride: 08' E90 M3
Custom wiring up the pillar I'm guessing.
cposk is offline   Reply With Quote
Old 11-13-2012, 11:55 AM   #3
IrunBimmer
My Ride: 323i
phenomenal, sounds like its going to be a good time
Old 11-13-2012, 12:16 PM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You'll need to remove the pillars and headliner.
Why though...? Are you going to sit in a parking lot somewhere and watch tv?
Old 11-13-2012, 12:33 PM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Because Americans need more things to distract them while driving.
Old 11-13-2012, 01:04 PM   #6
IrunBimmer
My Ride: 323i
First off I'm Russian thank you very much and no not for that I'm plugging my ps3 to it for passenger t play
Old 11-13-2012, 01:21 PM   #7
WDE46
My Ride: '13 128i, '04 330Ci
Are you a professional Russian or just an amateur?
Old 11-13-2012, 01:23 PM   #8
jeepo23
My Ride: 2008 X3, 6 Speed
He's clearly professional since he's installing sun visor tv's and ps3's.
jeepo23 is offline   Reply With Quote
Old 11-13-2012, 01:58 PM   #9
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
Stop bashing on the dude..
You will most likely need to run a ground cable and a 12v + source up through the passenger A pillar up to the sunvisor. (to power up the monitor)
then run down the RCA cables for L and R audio and the yellow Video cable to PS3. (Do PS3s only run on HDMI?)
Then you need to power the PS3.
G-Hots is offline   Reply With Quote
Old 11-13-2012, 02:06 PM   #10
trizzuth
My Ride: 231k, 16yr old B3AST
Ew. That is all.
trizzuth is offline   Reply With Quote
Old 11-13-2012, 02:25 PM   #11
IrunBimmer
My Ride: 323i
aright man, thanks sounds good, ill look at the layout of the wires
Old 11-13-2012, 02:30 PM   #12
eneka
My Ride: 2003 325i
how about the homelink pre-wires? wouldn't that work as a power source as well?
eneka is offline   Reply With Quote
Old 11-13-2012, 02:42 PM   #13
trj
My Ride: 325Ci
If you are only looking for power, then run a 12V line/or with a converter with whatever Volts you need for the monitor through:
fuse box->inline fuse->converter(voltage adapter)->A-pillar ->sun visor.
Same place can be used for AV cords as well.
I would recommend not to tap into the homelink wires. They are lower gauge wires and may not be suitable for you monitor. I'd rather run a slightly higher gauge wire with an inline fuse with lower rating.
There are empty slots in the fusebox. I used slot 4 or 5(I forgot) with an inline fuse, voltage converter and ran a ground cable to the a screw near the glovebox for my iPhone charger and aux purpose.
This setup will allow you to run your AV cables to the glovebox so you have minimal wire mess everywhere.
Be careful in running the wires through A pillars, DO NOT obstruct the air bag path.
Also, how are you planning on powering the PS3? inverter or something?
Old 11-13-2012, 02:45 PM   #14
IrunBimmer
My Ride: 323i
the ps3 im still thinking how to power it, temporarily i think ill connect it to my head unit. i had a friend with a similar setup. ill take what you said in consideration read up on it some more.
Old 11-13-2012, 03:20 PM   #15
maurer
My Ride: 04 Coupe
You should probably do yourself a favor and sell those things as quick as you can. Just tell your friend a lie as to why you dont have them anymore; girl friend broke them, someone stole them ect.
maurer is offline   Reply With Quote
Old 11-13-2012, 03:33 PM   #16
kaldE46
My Ride: 2001 325i
kaldE46 is offline   Reply With Quote
Old 11-13-2012, 03:47 PM   #17
///MPR77
My Ride: 02 ///M3 Tri-Ped
OP, it's nice of you to think about your passengers motoring experience.
I hardwired a monitor into my steering wheel.
(I know selfish right? )I just tapped into the horn wires, then I taped the horn down so that it was always on/hot...so that it could power up the monitors. Sure it was noisy with the horn masking the sound of the movies, but I found that wearing headphones to listen to the movies while driving around helped a bit.
The ideal set up would be a HUD projecting across your entire windshield, but that's a whole different thread.
Old 11-13-2012, 06:32 PM   #18
Lusticles
My Ride: 325Ci
I'm just surprised something like a sun-visor TV is legal.
number one Audi Fan
Lusticles is offline   Reply With Quote
